Yep that looks like the right one though, they have a better waterproof connector now. Just mention to her that you want the one for V brakes (I got a couple of roller brake ones once when I did not specify them correctly which was a challenge) and say its for a small wheeled bike. Cici will send you a PI (order sheet) which should list and have photos of what you are ordering.I have looked via the website but they do not mention the name Tongxin motor. Is this the right one?
Hangzhou outrider technology Co.,Ltd.
Btw, can I choose higher RPM (let'sa say 328) to improve the speed? as my commute route is pretty flat and the speed is my main concern.
As I said you may have to wait 4-8 weeks especially if they need to make one with 28h. 36h ones are fine but you will need to use a Sun CR18 rim which are stronger (does not matter given this lower powered motor) and are more of a challenge to get the smaller 16" tires on and off.
260RPM is the maximum though as I said some over volt them to get a higher top speed.
Regards
Jerry
