Change of PSI changed my biking life!
So I been running my 700c tubes at around 35 psi for the last 6 months and keeping my tyres up by using a hand pump getting them up till around 30/35psi. So I bought myself a full size pump and easily got my tubes up to 55 psi and my god it is like riding a completely different bike! So much nicer to ride now and MUCH faster! I'm now averaging 19.5mph on my commute to work up from 16.5mph just from the change of psi!!
Crazy such a small thing can make such a massive difference!
I think I'm going to write a noobie post with these small things I've found as I'm just fitting these things as I go!
Hope everyone is enjoying the lovely weather!!
Ride safe!
Hi, fellow forum new member.
Also you have saved yourself from pinch flats, I use marathon plus tyres , have not had a punture with them, I do very high mileage on several ebikes.
Ride safe!
.....and the distance you can cover on a charge will be increased as well.
A win win situation...
regards
Andy
What if you go to 80 psi? Will you be able to go even faster?
Almost certainly yes, 80 PSI works for me, less rolling resistance. Get a track pump and it takes half a minute.
My tyres are given a range of 55-80psi. As I only ride on tarmac, I always run them at 80psi. Be like riding through treacle at 35psi!
Ouch! £55 for a track pump. Think I got mine at Decathlon for less than £20 a few years ago. I'll stick with the old, uncool inner tubes I think! Not punctured for about 5 years - another advantage of sticking to the black stuff.
I pump my tyres to 70psi and check them once a week. I carry my pump with me in my rack bag and takes seconds to top up the tyres, it is very similar to a Topeak "Mini Morph" with it's own gauge. I used to pump my old bike to 100psi without breaking a sweat. The ability to quickly and easily pump up tyres whilst on the road takes out the worry of having to use a crappy hand pump, if a puncture were to rear its ugly head.
i got mine on offer for £35 but it is also has a separate chamber you can pump up to 240 psi to seat tubeless tyres on the rim.
even at 55 it is half the price of other pumps like this ;)
I had never heard of such pumps in 80 years! Withhand pumps I know it would take ages to get up to 30psi and completely forget 100+
Jim
Jim
If I could post a video, I would demonstrate it from a flat tyre. Takes quite a few pumps of course but no serious effort. Takes about a minute or two from fully flat to 70psi. It's the foot peg that makes all the difference. I never bother to use my track pump now apart for the rest of the family's bikes which have Schrader valves.
I use Marathon Pluses too and run them at 55-60 PSI (I do mainly off road on riverbanks and cycleways).
55 PSI for front, 60 for rear.
I have a nice cheap little hand pump (that has dual action and gets them up to that very quickly).
Go Outdoors Cheap Dual Action Hand Pump
Not sure how high it would go as I've not really tested over 65PSI.
I have a digital typre pressure gauge so always get the PSI spot on.
I've had my Merida Track pump for about ten years - less than £20, SO much easier than a weedy pump you keep on the bike.
As I lurk around various bike shops, (including the notorious Halfords), I keep seeing those sinister looking gas canisters for tyre inflation. Any good for emergency use on an ebike with 40mm tyres and schraeder valves, or are they best suited for skinny road bikes?
they do work but expensive for what they are and some tubeless sealant does not like co2 but better than a tiny pump.
I was just thinking that they are small and neat to pack for an emergency. I don't use gloop in the tubes so poor interaction would not be an issue. Are they single use only? I really must inspect them more closely.
In addition to all the win-win benefits already mentioned, you'll be getting much better tyre wear with the tyre properly pumped up.
A good hand pump can easily manage 80psi with a bit of time; a track pump is much better. I was lucky with a metal barrel £7.99 one in TKMaxx.
