Hi all, quick update, I tried a chain with one less link, no good, way too tight, so chain length is correct, 114 links, as originally worked out using calculator and same length as old chain.
I suspect it's a combination of new chain and existing chainwheel causing the chain suck. I think I'm gonna give it a few rides to see if it settles down before changing the chainwheel. it doesn't look to bad wear wise, but these 42t chainwheels are alloy compared to the bafang kit ones which are steel, so it will wear quicker no doubt. As mentioned, might switch to the stock 44t steel bafang I have new still in the box
Cheers all
Cheers all
