ce:g3m20211-1592-16 - Wires of Pedelec for swap to switch?
DustinAnderson
Jul 28, 2019
Thanks for the help in advance.
My pedelec sensor is dead and I want to put in an on/off switch on the bars...I thought it would be two wires and there are 6 .. :0(
I can’t find a schematic.
Is it possible to just use a two wire switch?
If so..
which wires?
DUstin
Andy-Mat
2,214
564
78
If so..
which wires?
DUstin
Not as far as I am aware.
The sensor must see a "rotation" and a "direction", hard to simulate with a switch!
As the PAS sensor (I assume you mean), a same/similar one can be bought quite cheaply on say ebay or a good bike shop.
I have never had problems with this part, but several people here are very knowledgeable!
With a bit of luck, one will help you soon.
Andy
DustinAnderson
Jul 28, 2019
Andy
Thanks brother
My sensor would frequently cut out in wet conditions. ... and it is wet frequently here on Vancouver island.
I could remove that set of wires altogether and connect a switch to another set of leads .
Does any one know of the other lead I could connect the switch too?
KirstinS
3,224
899
Brighton
As Andy mat mentioned it sounds like you are trying to replace the pas sensor with a switch
If that’s the case then you can’t replace with a switch . The sensor detects the magnets and sends pulses to the controller . A switch is just on /off and won’t work
However there are different versions and you should be able to buy a replacement that’s better for little money
Best thing would be to give us photos . Of your current pas sensor , bottom bracket /cranks and the wiring /connectors
More info we have the more exact the help can be
8,788
Water is ingressing and affecting the wiring/5v line most likely within the sensor unit. The wire entry will need water proofing and possibly the sensor it self as they often ahave a joint around them.
DustinAnderson
Jul 28, 2019
Certainly....I prefer to use an on off switch anyway and looking for help in this process. a
8,788
It's already been mentioned the PAS operation is designed/programmed so that a signal is received via rotation of a magnet/s passing a sensor , replacing with an on off switch won't work. Affectively the throttle is an on/off switch and gives in the whole no power or max power, you can try to feather in the power but it doesn't perform well that way.
If you plug the throttle in to the PAS it doesn't work, the programming /software for the two actions are different.
