Carrying a spare battery.
30,734
That's true Pete, the basket is a bit of a restriction. Obviously some top projection is necessary for that quick release hook system even if the bags were underslung a bit.
The only thing I can think of offhand is a spacer plate on the carrier centre line to raise the surface to the same level. Maybe a strip of softwood about 13" x 4" x the necessary thickness, painted to suit. The hook points could be cut out to accommodate those, and the board could be "U" clipped into place to keep it a permanent feature.
Alternatively, with U shaped small tool clips on the underside, it could be clip on and off, or yet again, perhaps it could be attached to the underside of the basket.
Ian
1,333
Leicester LE4, UK.
Ian. You might be pleasantly surprised. As long as you cycle slowly the terrier will adapt. My dog and I progress in a series of shuttles. First, I lead and then she overtakes...and so on. I often walk and push the bike and she happily copes with that too.
The fear is that because the dog stays so close, and is quite small, there is a risk of striking her with a pedal, or running over a paw. She is however a fast learner and we are fortunate in having a large country park nearby in which to practice.
