Carrera crossfire losing power
Derbynay
Jan 29, 2019
Hi I have a Carrera crossfire ebike.. it's about 6 months old only done 400 miles on it a couple off weeks ago it start turning off the power on the screen but it carries on for a few seconds before it is dead I have to press the power button for it to start up and some times it doesn't come back on it. mainly powers down when I move the handle bar to turn a corner and sometimes down a pot hole if I dont see it.. anyone no a fix for this.. I have the receipt for the bike but it's not in my name as I brought the bike off my uncle and halfords said the person who brought the bike has to take it in but he has moved away from the area any help would be helpful thanks for reading
3,993
This is a common and well-known fault.
One cause is when the LCD panel breaks contact because its holder doesn't hold it tight enough. You can solve that with a bit of thin plastic or some tape down the side/s of the panel to wedge it in tighter.
The next cause is when the battery terminals break contact when you go over a bump. You can solve that with a Velcro strap around the battery and frame to hold it in tightly.
The third cause is the motor connector on the chain stay, which is vulnerable to being kicked as you pedal. You can tape it out of the way to prevent that.
Finally, the battery self-diagnostics shut it down for no reason. There's nothing you can do about that except take it back tpo Halfords and demand that they fix it. Some are better than others.
Derbynay
Jan 29, 2019
Hi thanks for the reply I think I have found what's wrong with it when I turn right it turns off but when you go left It stays on I done it with out moving the bike so i check the wire at the back off the LCD screen and it was fine so i followed it down till i got to where the 3 wires are covered i touched that and it went off again so it has to be something to do with that do you have any solutions what it could be
3,993
It could be a wire broken inside the insulation. More likely, though, is a dodgy joint somewhere.
Derbynay
Jan 29, 2019
I un loosed the cable wrap and cable tied the wire to the frame I just went out on the bike and it only cut out 1 time as I was moving the cable wrap out the way but done 4 miles on it so I've found the problem for a short time fix
Andy-Mat
2,214
562
78
Guessing, possibly broken cable, one moving with the handlebars possibly.
regards
Andy
