Carrera Crossfire help
darren66
50
27
A friend of mine has just purchased a used (2018? 1100miles) Carrera Crossfire ebike from an online retailer of used ebikes...
Now this is a bit of a dog, if he'd paid £150-200 privately for it, I'd admit it is what it is and tell him to make the best of it, but he paid over £600! for what looks like £100 worth of Halfords "bicycle shaped object" with a cheap battery and motor attached.
I can certainly sort the buckled wheels, knackered tyres and pedals and realign the disc brake calipers for him, what I'm not sure about is the lateral movement in the rear wheel hub/motor, if this were a normal hub axle, I'd have it sorted in two minutes but this is a different beast, I don't want to go to the trouble of removing the rear wheel unless I know I can adjust that free play out, or does this just mean the motor and/or bearings are shot?
If it were my bike I'd be calling the seller to come and collect it and demanding my money back. Is it worth trying to fix?
8,551
Crossfire uses the troublesome Suntour system, £600 is a waste of money for a bike in non running condition. Rear hub lateral doesn't sound good, I have replaced worn sealed bearings in my hub motors and serviced them but never had lateral play as you tell it. If it truly has only done 1100 miles then yes it is a dog and been badly abused.
darren66
50
27
It does run (I think) at least it charges ok with no apparent fault warnings, I've ran up the motor in walk mode but that's it! my friend hasn't seen it yet, he purchased it and has been away on holiday whilst it was delivered to work, he will see it when he returns on Thursday, if this free play isn't easily remedied, I'll suggest he gets his money back.
Kwozzymodo
177
40
63
Lincolnshire
Sounds like wheel bearings. Fixable, but you will need to crack the motor open, press the old bearings out and acquire new ones to refit.
Don’t these online places offer some sort of warranty/guarantee on their bikes? If so, let them sort it.
darren66
50
27
It has a 14 day money back guarantee, I'll suggest he sends it back, it's not worth the hassle trying to put it right.
Reactions: Nealh
Kwozzymodo
177
40
63
Lincolnshire
If your friend is desperate for a Crossfire, I have one available (19” frame) that I can convert, and provide a 12-month guarantee.
Andy-Mat
2,214
562
78
When you say "it charges OK", what are you basing your comments on?
If its the charger green LED being lit, do not forget that LED has several different purposes:-
1) Charge finished - battery now fully charged and usable
2) Not charging - no current is being drawn, battery possibly defective
3) Battery below the voltage level that allows charging. I believe the BMS prevents unsafe charging, but It can possibly be recovered with a "0 Volt Charger", like this one, if you have a 36 volt battery:-
Where it is noted:-
Description
Use this to recover your battery if it has not been used or charged over a long duration of time. you only need to use this charger one time and then a normal charger can be used.
NOTE: Free shipping only applies when backed in conjunction with a bike as they will ship in the same box, otherwise shipping costs will be billed depending on country of shipment. once the recovery charger is returned to us, we refund the purchase amount so long as its returned within 30 days. Shipping costs are not refundable.
4) If the battery is even lower in voltage than that, (0 Volt Charger does not recover the battery) then to all intents and purposes, the battery is now junk.
The only way to understand what state the battery is in, is to measure the current voltage with a reasonably accurate volt meter or Multi Meter, and post the result here, plus the nominal voltage as well.
Please do not forget that the 0 Volt Charger I mentioned, is ONLY for bike batteries with a 36 volt nominal voltage, even though they forgot to mention that in the description, as Stark ONLY sells 36 volt Bikes.
Regards
Andy
darren66
50
27
Where it is noted:-
Description
Regards
Andy
The charger was lit red when plugged in and switched on, lit green after a couple of hours, I left it a couple more to be on the safe side although the screen only achieved 99% charge.
wheeliepete
2,047
757
Devon
As already said, the Crossfire was plauged with problems when new, deff. not worth £600, tell your mate to return it and get his money back.
darren66
50
27
Will do...
It's no surprise that 50% of the bikes for sale at the retailer he purchased from, are Carrera Crossfire/Crossfire II
8,551
It is only the Carrera bikes with the Suntour system that's not worth a light , others systems are ok and don't have the issues.
Andy-Mat
2,214
562
78
That sounds really good.
Did you manage to measure the battery voltage at the end of charging? If yes, please post here, thanks-
Andy
Deleted member 25121
Andy
I think the problem is excessive play in the rear hub not a battery issue. Have a look at the video.
8,551
Now I have seen the lateral play on the video the fix should be simple, on that side is located the press fit sealed bearing, a water seal and axle nut. It looks like the axle nut is certainly loose though whether there is any rough bearing rotation can only be felt by manual rotation. If the bearing is faulty/rough then the hub has to be opened to tap it out with a drift, I use a socket and rubber mallet.
Still I would be inclined to find a better system then the Suntour one as spares will be nigh impossible to get and they aren't generic.
8,551
The axle nut I mention is a cone type nut on the inside of the drop out on the LHS.
Andy-Mat
2,214
562
78
That gives me the impression at least, that the bearings are adjustable for wear, just like on normal bikes. Is that correct?
Andy
