Buy new Dongle or not?
Steve A
704
414
Ashford, UK
Had to do a a small mod to bike tonight.
The hanger is attached to frame via a m4 bolt about 10mm long. when i changed tyres noticed the hanger thread had worn and was loose.
Also, noticed the m4 bolt only threads halfway through the hanger (not great design.
Luckily i had same m4 bolt but 15 mm long. this now fixes hanger to frame much better. stupid why they didn't put a longer bolt through to use all of available thread.
hate my keyboard so have given up using caps lock :)
Reactions: soundwave
6,733
i might just have enough spare chain as that is 6 extra links so should be long enough now i went up 7 from 18t so extra 6 links should do it ;)
tho not sure i should link 11 spd chains like this as bit of a bodge job tbh as just re used the link pin.?
6,733
well it took 4 extra links but had the same problem as the connex sprocket as felt grinding from the motor in most gears so used the 15t i had as a spacer as the ses wheel put the chain on a angle inwards on the 25t sprocket.
i can still feel it grinding in some gears but might be the spacer in the ses wheel for the dual kit but it soon goes when i shift down to a smaller sprocket.
it is helping with lower rpm of the pedals but top speed hit a wall at about 34mph i only went round the block and is blowing a gale outside but i cant see you getting to 40mph on the flat and doubt if you did get going that fast would not be there very long at all as the motor is just doing nothing assist wise.
or im just not very fit lol i also had to adjust the b screw to get the shifting right again.
i also have to use the 42t at the rear just to get going and then just use the gears so on the flat using the full range of the cassette but my 42t is made of alu so will wear it out fast imo.
ill leave it on for a few rides and see how it goes but i think 25t is a bit to much on a mtb that is as heavy as mine 21kg.
ill add some pics later ;)
6,733
Steve A
704
414
Ashford, UK
Good spacing. The haibike original sprocket has a tiny bevel to help with clearance. IMHO, 25t is too big, as equates to a standard 62t?. I think 20t max which equates to 50t. The biggest older mtb used to have 48t, hence why i stuck with 20t as close to this. Also, not sure you would have gearing to climbs with 25t.
My 20t (original haibike sprocket) turned up today, along with the new bikespeedrs dongle (no limit assist / no cut out). I took some time fitting as ended up taking motor out of housing to fit.
Just waiting new chain as current one now a bit to short. Did a very quick test run, but only up cul-de-sac, so far to short to comment. I just wanted to see if it works.
My current dongle cuts out at 33 mph, but even with 18t sprocket and 11t cassette there was more to give.
I think the 20t (biggest i want to go), with 11t cassette and new dongle will get me to around 40mph. My cadence average is 85. On the internet some people have got to 45mph.
I'll test tomorrow and let you know. Thats if is survive :)
6,733
you might get it there but doubt you could avg that speed overall imo with this 25t just seems it accelerates faster through the gears.
i also think the purion is well of speed wise to what it says on the screen even half speed it dont look right.
i have 10t on the rear but seem to get a bit more assistants in the 2 b4 it but need to test it for longer with strava on me phone.
Steve A
704
414
Ashford, UK
Agree, i just like the idea of being able to hit this speed if i want to for short periods. I usually ride at about 20mph, cadence 85 avg, eco mode.
I have the garmin 820 and note the purion is recording 1mph more than the garmin all the time?. I sold Nyon, so can't comment on that one.
The bikespeedrs dongle records correct speed etc, not half.
I thought the baddass dongle was limitless, but clearly not?.
6,733
last time it cut out was with a 19t and 36 mph but this can be out buy 4% why i messed about with the wheel size and pushed the magnet back as far as possible so it just registers it.
the bad ass dongle is 50kph give ot take 4% thus why can get to 36mph or just under.
tho it would really hiss me off going down hill with it cuting out as it is like slamming on the brakes.
tho then again that would be a hospital class crash pmsl
6,733
it is way better than the old display and now hardly notice it at all back light wise tho there are screen tints you can get for it.;)
my 500w batt is on charge so will try again with that as i get more woof from that than my 400w as that is over 2 years old now just need to see if i can get that ses wheel more in line with the spacers i have.
Reactions: Steve A
Steve A
704
414
Ashford, UK
Well, just come back from a quick spin to try new dongle. I managed 36mph, but there's still a bit more to give so think 40mph is possible for a very very short period. Still waiting new chain, but not ideal conditions i.e. dark, wet and yes potholes (i'm not suicidal).
I think the Bosch motor (built for torque) looses assist the faster you go despite the dongle seller stating it's not limited.
Loads of assist up to 30mph, then the assist is still there, but less so and other factors play i.e. the motor and what it is capable of assist wise at speed and of course me!.
I wasn't really up for a ride tonight. I'm sure a decent cyclist could have hit plus 40mph, as on the internet with the bikespeedrs.
Post again when i give it another go, however 30mph plus is plenty anyway.
6,733
i can get 30 with the 18t but spinning the pedals like crazy so a 20t will help with that.
and yes you hit a point where the motor does not cut out but then the speed you are going does not assist any more.
the dongle is unlimited but the motor is limited to a certen speed and i guess you have found that now ;)
Reactions: Steve A
Steve A
704
414
Ashford, UK
Your right!. Still i'm happy that i can get well into the 30's which will blow most roadies away (i should know). :)
Got to do more testing with 20t see if ok on climbs etc, and see if i can hit the 40mph. OMG it's like being back on STRAVA!!!!
6,733
6,733
the last one is my m8s strava but if i had no dongle id be left for dust tho he rides a road bike most days he was kaput after that ride tho lol.
Reactions: Steve A
Steve A
704
414
Ashford, UK
Some people don't realise how good a road bike can be. I sold my old road bike, which when pushed could hit over 40mph on flat and with a lot of effort, but it was a 10k bike. Can't believe how much i've spent and wasted on bikes. Still my mates into building a Lamborgini kit car and he's already spend over 35k. Makes my hobby look cheap.
