Bulls bikes
6,486
no not that it matters you can get dongles for them that remove the speed limit just are 100 quid.
https://www.badassebikes.com/
others are wired in to the motor so not as easy to remove.
Crockers
821
689
71
15mph + 10% leeway. Just shy of 17 is therefore legal. But who the hell is going to know if it's 16.5 or 17.5.
IR772
931
1,044
Leominster
It will go a lot faster than 17 MPH, down hill and under your own pedal power on the flat.
It's only the motor assistance that will fade at that speed.
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
Reactions: IR772
5,786
It is a tolerance in EN15194 which is 10% for manufactured bikes and 5% for others (kits). I guess the manufacturers asked for that tolerance so they wouldn't have to spend a fortune testing and tuning each and every bike that comes off the assembly line.
Remember it can go both ways -10% :eek: as well as +10%...
Reactions: EddiePJ
5,786
My version is from 2009:
4.2.6
Maximum speed for which the electric motor gives assistance
4.2.6.1
Requirements
The maximum speed for which the electric motor gives assistance may differ by ± 5% of the speed indicated on the label described within Clause 5 when determined according to the test method described in 4.2.6.2, from 25 km/h or lower values as specified by the manufacturer.
During a production conformity check, the maximum speed may differ by ± 10% from the above-mentioned determined value.
Of course when I have the time I will print a label with Max speed 25 kph etc and stick it on the bike...
Related Articles
