If your charger is fixed at 3.6v, it'll be OK. I thought that you were just going to charge at 1 amp with no voltage cut-off, and stop when you saw 3.6v. The charge and discharge curve is "S" shaped, being nearly flat between 3.0 and 3,3v, but climbs/drops increasingly more rapidly either side of that.
Excellent D8veh, thanks for the info just what I needed to know. Over the weekend I connected a single cell to the dc converter at 3.60V and let it sit there until the amp flow slowed to nothing.
I let it sit off charge overnight and it held a steady, but lower voltage. Then when I was happy I hadn't destroyed it I connected the remaining cells up in fours in parallel (4p?) and put the steady 3.60V on them until baked.
Here's the part no. of the piece I was using.. LM2596HV (the HV stands for High Voltage) that is overkill for changing a single cell, the lower voltage (and cheaper) LM2596 would have been enough. However I want to input around 55V from the pack and convert to around 6V to run my bike lights.
I am thinking of buying 8 of these and building a little float charger, two cells at a time. I'll see how well the BMS keeps them all in check. At a couple of quid each it's a pretty cheap way of keeping them all in line.
Ignore the wire colours in the pic.. it was very late and I soldered the board upside down forgetting to swap the wires over.. I've only soldered stuff a handful of times so I was very pleased it all worked..
