Crikey! You're getting worse. Crank drives require less maintenance than hub-motors? That's a new one!
Well the 250W CD motor is fast enough on the flat at about 22mph and would be even faster for me if there was a harder gear. On steep hills I get about 11mph, but 15mph or more would be nice.How fast do you want to go?
The battery can take 2C without much to worry about, you can go up to 48V 24A on your battery, that's why I suggest BBS02 48V 18A 500W.How much are these higher power motors going to affect battery life though?
I realise battery life will be disproportionately reduced because at higher speeds the bike is less aerodynamically efficient, and the higher current use will cause vdrop to occur faster, and I'm guessing more power from the motors will also be lost as heat, unless the higher power motors are more efficient?
With the 250W motor on max power for say 16 miles on the Sirocco CD there is a noticeable drop in power output, so maybe I should add a couple more cells to my battery?
On that note how does hub vs crank compare on power usage to obtain a given speed on the flat or a hill?
As to the earlier comments about me having problems with gearing, to be fair as you well know the Sirocco CD uses the cheapest components on the market, I would be using a much better group set if I went for a crank drive motor again.
Sorry Dave but I disagree with the longevity figues you quote for high torque front motors, e.g. my son gets several thousand miles out of a set of Schwalbe Marathon Plus tyre on an eZee Sprint GTS which has a high torque front hub motor.Tyres last about 1500 to 2000 miles on a rear drive (crank or hub) and about 500 to 100 miles on the front, which is one reason you should avoid high torque front motors if you can.
Is he light? It makes a big difference.Sorry Dave but I disagree with the longevity figues you quote for high torque front motors, e.g. my son gets several thousand miles out of a set of Schwalbe Marathon Plus tyre on an eZee Sprint GTS which has a high torque front hub motor.
He's a big guy and weighs about 80Kg. but not as handsome as his fatherIs he light? It makes a big difference.
High torque motors have a tendancy to spin on start-up and when climbing steep hills, which is why they wear fairly rapidly. Saneagle has a front BPM at 30A. He's just worn out his tyre in about 300 miles from new!
Nah, ride it like you stole it.Maybe Saneagle needs to feed the power in gradually?
That's a rear motor. No wonder he doesn't wear out the front tyre!He's a big guy and weighs about 80Kg. but not as handsome as his father
Hi Eddie,Nah, ride it like you stole it.
That Ansmann is a nice looking bike.
Is that a through axle on the rear?
strictly for what its worth - I genuinely know nothing about pedelecs, but I have a friend who has been gratuitously hammering the crap out of a Raleigh twenty he built with a madly unrestricted BPM (last time I checked he managed to coax more than 2kw out of it, and that's mainly what he gives it) for as long as I've known him (about a year) without any broken anything (including spokes)..they are just trying to confuse you.
Power applied to hub = risk of breaking spokes,
More power to the hub to climb your steep hills increases this risk.
the bad road surface makes this risk into a near certainty.
