Hi Folks
Its finished ( well for now ) and I have been out for a ride .
So far the initial test report etc .
the motor is quiet and smooth and the controllers five assist levels have a definite "step " between them , the pedelec sensor kicks the system into life after a complete revolution and the brake kill switches work well .
A
BIG THANK YOU to D8veh for all his help in producing a rather nice upgrade to the trike and the technical support provided during the process .
Fitting the 11-30 freewheel and the 48-38-28 front chainrings have produced a rather nice gear range from 17 " up to almost 90 " plenty of range and a gear for all occasions the "geared freewheel hub " helps when in pedal power mode and everything is OKay
But There are a few criticisms that do not reflect on Dave's part only the differences in fitting a bike kit to a trike and sourcing parts
The cables are ALL either too long or too short and some cannot be shortened so have to been hidden this does take extra time to tidy up the installation as the whole of the installation bar the LCD display and the pedelec sensor are within a couple of feet of everything
And be careful where you buy from GBH took over a month to deliver the freewheel after purchasing an in stock item that turned out to be out of stock
now what shall I do with a spare e-wheel and a couple of front wheels ..........
you have probably guessed right
Seriously ,
Thanks Dave you have done me proud .........
