You can fit a rear motor to any Dahon apart from that new one they had at The Cycle Show with 16" wheels that folded as small as a Brompton.
Here's an idea of what's involved:
http://www.pedelecs.co.uk/forum/electric-bicycles/10584-electric2011-dahon-jetstream-p8.html
missing photos here in reverse order:
Dahon Photos by d8veh | Photobucket
You can now get the Q100 already built into a wheel with the cassette version motor, so you can use your existing gears and you can get in-line brake sensors, so you can keep your existing brakes. You can get everything you need from BMSBattery for a very simple conversion that should only take a few hours to do.
Q100C CST 36V350W Rear Driving E-Bike Motor Wheel - BMSBATTERY
Edit: Note that the motor in this kit is 201 rpm which is too slow for a20" wheel, although they do the 328rpm single motor, so ask if you want the high speed one built into a rim.
