I didn't check to see if it would fit in the frame. Problem would be where in the frame you would put it and getting the wires out ?Do you know if the controller would fit inside of the main frame tube? Putting it inside probably not a good idea but curious to know nonetheless.
As I said my whole project is to keep the "carry weight" of the Brompton as low as possible.
Dimensions shown above. It weighs around 220gms.
Some one else told me Sky was a woman. I will ask her next time I email him/her.Are you sure Sky is a woman? I knew a guy named Sky. It's one of those names that could be male or female.
Would you be able to do estimation on battery consumption for your work/home commute in comparison to the Nano? I'm not sure if you've ever measured how much juice the nano used on average for the commute. Sorta like an estimation without a cycle analyst to figure out the Wh/km. It certainly seems very similar to the Nano in performance based on your review.
Currently I use between 600-800mAh on my 5.25 mile commute one way pedaling quite a bit myself but remember my commute is pretty flat in Cambridge. A lot is dependent on terrain, weight etc.
This is using my current Nano motor and DIY battery 36v, 2.3Ah 12s1p A123 cells.
Build details here.
Regards
Jerry
