broken cable help
8,734
You was nearly there with the original repair so will have to try again.
For mosfets try and drain them of the voltage for a better reading, disconnect the controller from the battery and then to touch the controller Black v- & Red v+ together to drain the the voltage. This will give a brief spark but won't do any damage.
Double check the Green mosfet that gave 8 ohms reading and use the 20 ohm scale.
If it still reads low it may be worth replacing it. Also do check them again against the Red wire.
billyboya
1,137
90
73
uk
The mosfets don't give a voltage reading, the reading is ohms resistance.
The one at 8 ohms is quite low and is weaker then the other two it should be nearer to 9.7 ohms.
The Halls will have an identifier number on them, I can't read them as the pic is of poor resolution when blown up. Use a mag glass to red them.
So do you think the green mosfet is bad and needs replacing, as I didnt think I would need to remove controller and open it.
I cant read the hall sensors identifier numbers as nothing on them, probably, rubbed off when i cleaned the motor. But I have ordered 3 from where you said, just hope they same as I have.
billyboya
1,137
90
73
uk
The Green/Yellow phase wires look fried to me and looks like the Green has overheated and the core visible.
The Halls, one has to solder the correct leg and check they are orientated right as they only fit one one with bevelled edge. Use the white sheath to insulate the legs when soldered.
No what you thought was fried is just black liquid installation tape
What is that white stuff in circles. as it seems like some strong paste
billyboya
1,137
90
73
uk
yes I have had this happen before made me jump as thought i had blown something
ok will do that and get back to you
billyboya
1,137
90
73
uk
Im a bit lost as you say disconnect the controller from the battery, But I have not had battery connected at all for these tests, as you said no power. Ive just been testing wires not even connected to battery. But I just did touch thick red and thick black wires on controller together, but no spark. and retested them again
no power thick blck wire on controller
green= 08.11v
no power thick red wire on controller
green=17.76v
8,734
A strong heat resistant double sided tape to ensure the Hall pcb stays attached to the insulation barrier beneath it.
8,734
green= 08.11v
green=17.76v
I don't know why you keep insisting of writing up as a voltage test is a resistance test and should be denoted as such by writing ohms or inserting .45632
8,734
I would replace the Green mosfet as it is a weak link and may thermally cut out.
billyboya
1,137
90
73
uk
I don't know why you keep insisting of writing up as a voltage test is a resistance test and should be denoted as such by writing ohms or inserting .View attachment 45632
No you getting me wrong, I just said when you quoted about disconnect the battery, was just letting you know I never have battery connected anyway.
billyboya
1,137
90
73
uk
I maybe able to solder in the 3 hall sensors by just leaving that white stuff there, as it seems very hard to remove and dont want to crack that board.
billyboya
1,137
90
73
uk
Ok so what mosfet do I get or will I have to open controller 1st to check. as I believe there are 6 in all 2 of each - and +
billyboya
1,137
90
73
uk
Ok I have now opened the controller, and it seems I was wrong its not 6 mosfets, its 9 it seems 3 for each phase colour. I have looked at 1 and it has on it. so what do I order. the green wire is C then
CS48N78
45195 33S
billyboya
1,137
90
73
uk
Well it seems I have made a mistake with checking the mosfets, as now I have removed controller from moped and retested the phase wires its seems its all ok
so it seems the cable just fried 2 hall sensors. btw will those ones I ordered same as you said fit into those slots on motor ok and do they need to be Loctite glued in
thick black wire from controller + green = 9.79 ohms
thick black wire from controller + blue 9.81 ohms
thick black wire from controller + yellow 9.79 ohms
thick red wire from controller + green = 19.48 ohms
thick red wire from controller + blue = 19.46 ohms
thick red wire from controller + yellow = 19.48 ohms
8,734
Good, the mosfet's are consistent.
billyboya
1,137
90
73
uk
Yes it seems I removed the test probes too quick, as numbers was still going up, so I thought best to wait until they slowed down
Why is there 9 mosfets, do that mean 3 for each phase wire then, and how do you tell which are + and - Im just curious nice to learn stuff
Also I have ordered 3 of those hall sensors as you said. will they be same as mine, and are they stuck in slots with glue. also do they go in slots with the writing facing you.
I will have to be very careful how I solder the legs in as they mustn't touch, well only a small amount of solder on each leg it seems
Btw what did you say that white liquid is called what sets very hard. as I will probably put some over the wires before I close motor case
God its so hard to get the 2 end sensors out middle one was ok as I could push that one easy out. is there a special way to get them out probably a sharp pointed needle
there is some here too.
8,734
You can glue them in.
The Halls only fit one way correctly that's why they and the slot for them have a bevelled edge which means the writing is usually on the face showing outwards.
billyboya
1,137
90
73
uk
its so hard to remove them, some of the legs have even broke off, and lost the tubes for some. but its hard DE soldering them too I have not received new ones yet. will they be same as I have
8,734
The Halls should have a number identifier on them, one will have to use a mag glass to see this number.
The ss41F are pretty standard type to use on hub motors, hopefully they will be good for yours but best try to check the number on them.
billyboya
1,137
90
73
uk
Well no way do they have a number on them, as I would say they been there from new, and numbers rubbed off. the middle one was so easy to lift up but god knows how I am going to remove the end 2. as i just tried far right one and its even lifting up the metal of magnets. well if it is magnet, but I think that's on the wheel inner. I hope new ones have installation plastic on the legs, as I only have 5 so far probably 8 once i get middle one off the circuit board, so hard when trying to de solder. I do have a suction tube but that wont take it all. do you think that this board will still be ok
Getting there I'm glad now I bought mini drill and bits. IE grinder etc as removing old sensors slowly I'm using the middle one as a guide if that fits its all cleaned out ok of slot, the middle one was easy to remove, but it seems the end 2 are glued in
3,344
Acetone dissolves some glues, including superglue... but I'd be extremely careful trying it! It strips paints and protective coatings! Using acetone on circuit boards may dissolve them, but to get those components out of metal - just dab with a cotton bud and a small amount of acetone, and see if it loosens up? You might have to dab small areas and leave them for a few minutes, repeat a few times. Maybe worth a go?
Reactions: joelectric
