Bristol Show
  • Start date
Right, I've just done a bit of investigation. According to Google Earth, the race length is 0.14 miles. According to the video, the duration was 33 seconds. The average speed therefore was 15.2mph. Allowing for the 4 seconds it takes to reach 15mph, and the fact that the hill is less steep at the bottom half, so speed would be above the average for that half, I would deduce that the riders were doing slightly less than 15 mph for the second half of the climb, in which case Colin would be correct about the motor running, but incorrect about Oxygen cheating.
When you record a video with a fixed camera, you get a pronounced wine from the motor. For the following video, the motor was rigidly fixed direct above the motor, and you can hear the wine quite loud when the rider turns the bike at the start and finish of the race. You can also hear it cut after 4 seconds of the race. The wine can't be heard during the rest of the race, except that there might just be something in the last 20 meters. There is some chain and tyre noise that may be drowning slight motor noise as it cuts in and out with low power, but judge for yourselves. If I were on the adjudication panel, I would find in favour of Oxygen. Let's have a vote.
Video coming shortly.
Artstu
2,421
925
To me in the first video it looks like It only needed a fraction more assist speed to win, perhaps it just boils down to a 1 mph or so difference ?
trex
7,703
2,671
the video is 33s long but the race up to the finish line is only 29s - check the time index.
Average speed: 17.38mph
This is the one. I measured 33 secs from go at 1:11 to crossing the line at 1:44. In the first video, they've already started before the video:
tillson
5,253
3,197
Just out of interest, I've had a look at this. The race distance is 243 metres (Starting from outside Park House / Java to the south of the St George's Road junction, and finishing on the north side of the Charlotte Street junction) I used a measuring tool which we use at work (Measure Map).
The race duration was 32 - 33 seconds, I can't work out when the front wheel crossed the line, but the rear wheel was certainly over after 33 seconds.
To travel 243 metres in 33 seconds gives an average speed of 16.47 mph.
Does the measurements of the race distance from a map take into account that it is on a slope
http://www.ams.org/samplings/feature-column/fcarc-surveying-one
That mapping system has errors. Look at the start frame of the first video. You can see the slope of the hill from the line of the railings. It doesn't bear any relationship to the above picture. The actual slope has a slight gradient for the first 10 meters or so, then the next 50% is a constant gradient, and the next 50% is slightly steeper
Wicky
2,823
4,011
Colchester, Essex
www.jhepburn.co.uk
If you are measuring the horizontal distance from a map then the race distance travelled by the bike up the hill will be underestimated. Therefore the average speed will be overestimated.
trex
7,703
2,671
You mean underestimated surely?
ground distance: 243m
elevation (Park House): 24.4m
elevation (at the top): 47.1m
race distance: 244m
average gradient: 9.3%
steepest section: 14% (half way up)
If the race was run in 33 seconds, average speed is 16.6mph
Then the rightful winner is the one with the motor off the longest.
Hold on, I thought it was the electric bike word championships, not the non-electric bike world championship. We need to find a steeper hill so that the motor's on all the time.
tillson
5,253
3,197
race distance: 244m
Yes you are right trex, if the distance is underestimated that will result in the speed being underestimated.
tillson
5,253
3,197
is it just me or does that video suggest the assist is on all the way up on the Oxygen?
I've not ridden an Oxygen bike, but my understanding is that if you are riding above the cut off speed, the motor does just that, cuts off, effectively making it an unassisted bike.
The bike being used on that video didn't sound like like an unassisted bike at any point during the race.
exactly...
because its possible to get above the cut off speed, and the short distance, mean I would have been faster on my road bike.
But I stand by my point... the Haibike and KTM cut off on that hill when the riders got over the speed. The Oxygen didnt.
Jimod
1,065
634
Polmont
To be fair, it does sound like the motor is on all the way up the hill. Of course, that's not scientific as we don't know what the top speed is.
On a personal basis, I'm not bothered about it one way or another. However in the interests of fair play. Oxygen and KTM need to send me a bike each for a month. ;) Come on, you can't blame me for trying. :)
D8ve
2,142
1,294
Bristol
Doing 16.8 is just within the tolerances if a legal bike but to be fair it did seem to run all the time.
It's not sour grapes from KTM but no real evidence of foul play by Oxigen either as tire size and pressure can all factor into it.
A win to Oxigen but no dishonour to KTM as they cycled a fair hard race. On a good bike too
billadie
295
48
Tewkesbury
Did I see someone on a grassy knoll about two-thirds of the way through the video?
