Yep, thread looks like its Whitworth or something....not even metric....funny old lot the Brits...Whitworth left hand thread..
I think you might find it is 5/8th inch British Standard Pipe thread. Which thread standard, despite its name, has been widely adopted around the world (not USA). Including, for example, France, specifically for plumbing.
Reactions: robdon
Afraid you are wrong on the long lived with diesel. There are oxidation, water and bug issues. Its probably the worst fuel to store long term ,unless treated with emulsifiers and antioxidants. This is especially case if used on common rail or any very high pressure systems. ( smallest amount of water will destroy injectors)
Suppliers recommend no more than a year and preferably under 6 months...( Google storing diesel)
LPG will pretty much store indefinitely ( no air contact) Petrol will store quite a,while but certainly goes off..( smell changes)
I wouldn't use old diesel on any modern car engine.
During war and for military purposes additives were added to prolong shelf life. Diesel is degrading from.moment it leaves refinery.
Also, during winter months additives are added to prevent waxing. Store summer diesel into winter and you,ll get thick diesel clogging filters and poor starting.
Sealed plastic containers. The only path for moisture or oxygen is via the plastic walls. I am very familiar with waxing .. happened with our kerosine when the temperature went below -10 c a number of years ago.
Reactions: robdon
The thread used on the French gas system from the cylnder is not any of the normal pitches used and is not interchangeable with anything else. . While the French plumbing does use the same thread and in some cases the fittings are replaceable with Irish and UK fittings, the same is not true for the olives and copper tubing. You cannot use UK olives on Irish copper pipe or French olives on UK pipes etc etc. They may look the same but collapse at different pressures and Bite into the copper differently... The only way to be sure of leak free compression fittings is to use the same country pipe and olives.
Reactions: robdon and Zlatan
More nonsense from the Express
Brexit EXPLOITED: 'Opportunist' EU shocking member states by pushing UK out of Galileo
So they should and further down they give a logical reason
EU bosses have maintained that Britain will lose access to Galileo as a result of Brexit, most notably the satellite navigation system’s Public Regulated Service – an encrypted signal available to government agencies, militaries and emergency services.
Brussels said sharing sensitive information with a third country – which Britain becomes after Brexit – “irretrievably compromises” the service.
But to Brexiteers what we want is all that matters.
Reactions: robdon and oldtom
From the Independent
Gaza: UN to launch war crimes investigation into Israeli forces’ shooting of protesters
UN human rights chief slams Israel's 'wholly disproportionate response'.
Watch for those who leap to Israels defence.
Reactions: robdon
oldtom
Nothing more than posturing by another in a long line of spokespersons for the toothless UN!
Here is the list of all the post-WW2 Secretaries - General of the UN. They all made occasional noises similar to the current incumbent but nothing has ever been achieved in settling the middle-east disputes nor in feeding Africa or resolving the Balkans conflict. A buffer zone here and there is about all I can credit them with over the last 70 years.
I can't imagine anyone in Tel Aviv or Jerusalem is quivering over this headline.
https://www.un.org/sg/en/content/former-secretaries-general
Tom
Reactions: robdon
The UN was crippled at the outset by the USA. All other countries wanted it to be based in Switzerland to be truly neutral, but the USA insisted it would have to be in their country or they wouldn't support it.
And ever since they've flexed their muscles over it, for example having never paid a cent of their UNESCO dues since 2011 as a protest against Palestine being admitted as a member of the UN. Israel also predictably stopped paying then, and some others have joined the fee dues refuseniks, including the UK. The USA alone owes UNESCO over half a billion dollars.
17,441
I am not defending Israel - but there is no possible solution to the conflict in Palestine until all neighbouring countries and Palestinians accept the right of Israel to existence.
Zlatan
8,086
4,290
FYI
BSP use Whitworth thread (55 degree)
Since all female sealing threads by convention are parallel a Whitworth bolt ( and no other , would go straight into insert, if it was lht)
From Wiki about BSP.
The thread form follows the British Standard Whitworth standard:
◾Symmetrical V-thread in which the angle between the flanks is 55° (measured in an axial plane)
◾One-sixth of this sharp V is truncated at the top and the bottom
◾The threads are rounded equally at crests and roots by circular arcs ending tangentially with the flanks where r=0.1373P.
The thread is Whitworth.
Don't ask me why BSP decided on Whitworth when so many others were already flourishing, perhaps tooling ? Or perhaps it was established prior to UNC/ UNF / AF etc etc ? Not sure...but it has caused plenty of problems over years...and gives suppliers a monopoly???
Zlatan
8,086
4,290
Nobody can deny its existence just its locality...why in Palestine ? Because us and USA decided so in 1947 ? Rather tenuous??? Suppose they,d chosen Cornwall ? Charlie would be dischuffed ?
17,441
I read Leon Uris' Exodus years ago. That made a big impression on me.
I have always felt for the refugees and the displaced, israelites and Palestinians included. Palestinians and Israelites are cousins if not brothers. May they live peacefully together one day as one country.
I recently read a fantastic tale which involved a faked nuclear explosion contamination incident which made a section of the Navada desert a no go area. Then over a 10 year period, Jewish benefactors paid for the building of infrastructure on this contaiminated land. Then on a specific date and with total secrecy, the entire population of Israel decamped and made their way there... With the support of the US administration, who were in in the scam.. if only it were that simple. But and think about it a moment, the population moved was only 8 million or the population of London.
And those Palestinian families, still holding their door keys after 70 years could return to their family homes.
Reactions: flecc and robdon
there is no possible solution to the conflict in Palestine until all neighbouring countries and Palestinians accept the right of Israel to existence. - - - - - - - - - - - - - - - Palestinians and Israelites are cousins if not brothers. May they live peacefully together one day as one country.
This cannot ever happen due to Israeli policy, which is to wipe out all record of the Palestinian name and Palestinian existence in a deliberate form of ethnic cleansing.
The government and Jewish people of Israel refuse to use the name Palestinian, always referring to them as Arabs. When the Palestinians gained membership of the UN after a long struggle, both Israel and the USA stopped paying UNESCO dues in protest, and in 2017 both resigned from UNESCO membership. This is because they will not accept the existence of Palestine or Palestinians, only Arabs and Israel.
Once again we see the immense international bias. It's Israel that won't accept the existence of Palestine, and why they will never allow the two state solution, yet all we hear is that the Arabs won't accept the existence of Israel.
The basis of the Zionist claim is that when the Romans expelled them from 66 AD on, they gave the area of Judea the latin name of Syria-Palestinia. The Jewish claim that God had given them that land makes it impossible for them to accept the validity of those names, so they act against Syria such as taking the Golan Heights while historically deleting the name of Palestine.
It follows that there will never be Israeli - Palestinian peaceful co-existence until the Palestinians reject that they are Palestinian and become Arab citizens of Israel with Arab-Israeli nationality.
That's never going to happen.
17,441
for good reasons.
The human race is not civilised enough to avoid war altogether.
We can discuss this another time.
for good reasons.
Or as we have seen recently even our own government is prepared to use false truth to justify indulging in air strikes, merely as a diversionary tactic.
Sent from my Moto G (5) using Tapatalk
Reactions: robdon and flecc
I can easily believe that - my reply was actually meant to be about Calor threaded. Obviously I have confused by my less-than-perfectly worded response.
Reactions: robdon
