Bosch Spider Tool alternative
Does anyone know of an alternative to this? I don't really want to buy one for just a once a year job, and looking on you-tube the vid using a big wrench doesn't look too cool either.
Any advice appreciated...
I didn't use the tool.
I tapped the ring around with a blunt screwdriver and a hammer.
Came off no bother at all.
It is plastic, by the way.
Early ones are metal. tapping it round is a good option, it's a lefthand thread isn't it?
Never been much good with the hammer spanner...
Yes.
Hi,
The tool is only £29.99 on my website here - http://www.e-bikeshop.co.uk/bosch-spider-tool
It's the sort of tool that is only used once but makes your life 100times easier when you have it.
The amount of plastic lock rings I sell because people have 'mashed' up their current one and probably scratched the in the process.
At current we have only the performance tools in stock. I am expecting another 30 spider tools in when they are back in stock with Bosch.
Regards
Martin
Hi,
Regards
Martin
Thanks Martin.
It is 100% not that tool on CRC.
The Bosch spider tool, is only available from BOSCH.
Regards
Martin
Looking like I will have to spend the £30. When they are back in stock.....
Expecting a big load shortly, however the Germans have not given me an expected so looking like at least a couple weeks.
I do have spare spider lock rings in though, should you end up using the screwdriver in the meantime.
Regards
Martin
Regards
Martin
No rush... I only want to take the stone guard off to clean it out... First post.. Hole in front of casing...
Need to tighten mine but how does the pedal 'leg' come off for spider tool to fit. Had it come loose twice now and nice farmer happened to help me on Wednesday with tightening it with a big wrench.. Ironically my brand new spider tool was at home. It is now packed with the bike.. BUT I undid the bolt on pedal leg but leg would not come off??
You need a puller like Rob posted in post 2.
http://www.chainreactioncycles.com/x-tools-crank-extractor/rp-prod10181
Thanks.. Had thought crank meant the bit inside? How come the pedal leg won't just come off after taking the bolt going through middle of it? (Female logic)
Thanks.. Had thought a crank was the inside thing and that pedal leg things would simply come off.. Strange that it's not that simple.
