Bosch cx motor failed again 4th
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
I mostly see it on fat bikes, where the sprocket has been made by the manufacturer to stick out further to help the chain miss the rear tyre. These seem to put a high side load on the sprocket and some definitely become lose. But often, it's caused by fitting the wrong sprocket.
People also seem to have a habit of leaving the rubber O ring off as well. How much of a difference that it might make I have no idea, but figured that it was fitted for a reason, so leave it in place.
6,691
never used the o ring on my bike, i dont think it even came with one tbh.
Bearing Man
115
149
Hampshire
www.ebikemotorcentre.com
Some have O-rings some don't. Tends to be different depending on different sprocket types. The Haibikes have one for example, but probably shouldn't. The spider nut tends to cut it into little bits and squash it beyond recognition. :rolleyes:
6,691
the lock ring for my haibike sprocket had a gap what imo the o ring was for.
34166
any other 3rd party sprockets i used a lock ring with thread all the way.
34167
i have had no problems not using a o ring but if you use the one above it will just squash it to nothing and be a waste of time and make the sprocket loose when it falls to bits.
Reactions: Bearing Man
Jst_at_home
36
13
72
Just had a phone call this afternoon from the bike dealer. Bosch have sent a new motor. That's good and quite a relief. However I will try to get a proper report on what the problem actually was. Many thanks for everyone's comments.
John
Bearing Man
115
149
Hampshire
John
Result! :cool:
ABZ Scott
Oct 30, 2020
Hi everyone just after your opinions on this :
I bought a 2017 Cube Stereo Hybrid team action in November 2017 new still under warranty .In that time i've had four motors in that , bike shop and bosch been good and warrantied the motors but motor no 4 has just failed today and i'm sick to death of the bike now . Well not the bike just the bosch system , does anyone know what my rights are can i ask for a exchange of bike with a different motor brose shimano ? Or just ask for a refund
Cheers, Mark.
Hi Mark, I am having similar issues, I have Scott Spark eRide, on my 3rd motor and not impressed. It's a 40 mile trip to the nearest Scott dealer (no other bike shops in Aberdeen can sort is apparently and has to be Scott approved dealer), the usual back and forth with Bosch ends up in replacing it. It takes ca 1 month to sort it each time. I love the bike, we have great days out and I know what I'm doing from a maintenance perspective, not submerged it, not power washed it etc etc. Are we just unlucky?? I really am considering just selling it and hiring each time to get rid of the hassle. I am also looking into Shimano and Brose to see if they are any more reliable, cycle to work time coming around again.....
6,691
it does happen but not that often since i have been a member id say 10 ppl or less has had more than 1or 2 motors replaced under warranty but 1 month is taking the pi$$.
the dealer should be able to ask bosch for a report why each motor has failed ie is it the same thing braking on each motor or something different.
my 2014 boch performance motor is still going even with a dongle but the motors with the least amount of problems reported is the Yamaha motors.
ABZ Scott
Oct 30, 2020
I must be really unlucky then!! different issues, first was updated kiox software, error 500 immediately came up, bug in the firmware update apparently but new motor needed! Next was error 500 and 550. Intermittent engagement of motor, motor to be replaced. I have asked for feedback from Bosch, let's see if they give any. Like I say, an hour each way to the bike shop and weeks without my bike are pi@@ing me off!! I'll maybe give it one more chance, this will be costing Bosch a bomb
6,691
the problem is bosch are like apple the dealers cant keep spare motors in stock and they wont send out a new motor unless the old one has been logged in to there system for warranty replacement.
now as you have had more than 2 motors you could claim the bike is not fit for purpose and demand a full refund or a different bike with a different brand motor.
cohenfor
Nov 1, 2022
I have a Cube Cross Pro with the Bosch CX Performance motor. It has been fine for the last 20 months and almost 5,000 miles.
Reactions: Fat Rat
AndyBike
1,600
669
Well thats good for you, but what do you want ?, a certificate of excellence.
My Bosch Gen 4 has been fine in use, but that doesnt mean that others havent had problems.
  • Dislike
Reactions: Artstu and Fat Rat
Fat Rat
1,903
726
UK
I think he is trying to put across that there not all bad
So many threads are doom and gloom but not many on the life of motors when the going great.
And your reply is pretty shitty to be fair.
Related Articles
