The Q100 doesn't work too well sensorless. You should have got the S06S, which can use the hall sensors, which will give it a smooth start-up
Your controllet gives 15A at about 40V, so power used is 600w. It will achieve about 80% efficiency, so max output power will be 480W. The Emotion runs at 20A , so 33% more power.
As I said before, the orientation of the magnets is important. Did you copy the original configuration? Also, the5 gap mustn't be more than a couple of mm.
