BMS battery
dbar
66
Yes every thing looked ok to my uneducated eyes. I'll check again when charge has finished. Up to 3.3v now.
It'll rise quickly at first, but to get to 4.2v at .5A, it'll take 20 hours or more. After a couple of hours, you can turn the charge current up. after a bit more, you should be able to check that the switch works.
dbar
66
It will be tomorrow then.
Thanks for the guidance up to now.
It must be hard trying to explain things at a distance to people who really haven't got a clue.
It's easy with you because you do what you're told and give concise answers. Also, I know that battery pretty well, which helps.
dbar
66
Started charging again this morning. I didn't want to leave battery unattended. The bank I'm charging is up to 3.9v and the pack voltage is up to 41.2v. The light on the battery now lights up. What next? Should I try to discharge it and then try with the normal charger?
All the other cells are 4.1v to 4.2v, so you need to go right up to 4.2v to get it balanced. Can you estimate the total amp-hours gone in to it now and when it's finished? That will give an idea if it's OK.
What current are you charging it at and how many amp-hours is the battery?
dbar
66
I'm charging at 2.0amps. Battery is supposed to 14.5 amp. Cells are NCR18650PF.
It should therefore take about 7 hours to charge. Anything significantly less would be worrying.
dbar
66
Up to now it probably been about 10 hours. Now up to 4.14v and pack voltage is 41.1v.
Now you can try it. If next time you charge it, you get above 41.5v, it's probably fixed. It's still a bit of a mystery why that string was down unless it's powering the BMS.
