I paid less than £20 IIRC. £205 is miles too much. How did they calculate that? It's very worrying.
Greed is king, NRG. Some things never change.Seems the belt is being tightened. Just been stung for an extra £16 on a £20 item from HK, that's £4 VAT plus a ' clearence fee' from a company in London that I've never heard of. If this continues I'll certainly pull back my spending which completely goes against what's needed in these times of financial worry...
Bad luck. Hopefully they'll just use the value on the paperwork (about $50), so it won't be too much. keep us informed. Merry Xmas.Uh oh!
I checked the progress of my shipment tonight and found this....
'Tendered for delivery without success because of outstanding payment of charges. The item is being held and the addressee is being notified.'
I wonder how they'll calculate this?
It's my bpm motor, i suppose they'll be looking for a copy of the invoice?
Happy Christmas everyone
It works on speed. You have to pedal at a certain speed before you get power, then the power is proportional to your pedaling speed. Change down and you get so much power that you can't pedal fast enough; change up and you lose power, which makes the bike slow down: Not very clever really! That's why I changed to my cruise control.Finally found some time to spend on my new build this weekend and took it out for it's test run. I fitted a 10a circuit breaker to use as a switch and it obviously is not big enough which I found out on climbing the first hill. Still not much of an issue as a larger one should fix the problem.
The other thing I found is the pedelec stops working after about 10mph. It is fine up to that speed then as I go into 4th gear it stop's working. I have checked the connections to the controller and all seem's fine.
Any idea's what the problem could be?
Thanks for all the help so far it is much appreciated.
Alan
I got stung on a second hand keyboard. Trouble is they charged 20% VAT on £108 rather than $108 as was clearly specified on the docket. Oh and £8 quid handling charge. This was Parcel Farce....Bad luck. Hopefully they'll just use the value on the paperwork (about $50), so it won't be too much. keep us informed. Merry Xmas.
Okay Cost of bike is:Nice result. Can you itemise all the costs?
