Hi Everyone !
Sorry for the late response ... crazy weeks ....
So at last I've tried out the bike, should have planned a little test run but I did not find the time and just commuted to work yesterday.
attached are the details of my trip, around 26 km round trip with some serious elevation.
The battery was pretty much drained when I got home (and it was uphill so I was really afraid to run out of battery ...)
On the downhill part, the ride was easy :
- On flat part : around 30 to 40 km/h with no pedaling.
- Downhill : up to 60 km / h which was kind of too fast
- Uphill : with 5 % elevation I could maintain 20 km / h speed with moderate pedaling
On my way back I ran into more steep elevation, around 10 %. I took quite a effort to stay between 15 to 20 km/h, I arrived all sweaty but it was intended as the scope was to get to work fast and effortless and go back home with some cardio workout
So in the end, 30 min forward and 35 min back. that's acceptable. Today I made the downhill part in 25 min, nice
Concerning the performance, I confirmed that 328 rpm Q100 motor with 10 amp max continous battery is a little weak. The torque is not very good and the uphill part could use some additional amps.
I think It would have been more wise to :
- get a 201 prm motor and a cheap 48 v battery
or
- get a better battery with higher discharge rate
Apart from that I run into this error :
01_error Throttle Signal Abnormality;
-> It happens when I go back and forth to quickly/opten with the throttle
And the biggest issue and very frustrating is that when I push the throttle and that the load is to high the power shut down, which means I have to start pedalling to lower the load before pushing the throttle. Happens uphill at low speed / start. I don't know if it's the controller or the battery that shut down, the battery should be able to supply 20 amp for a short time so I assume it's the controller that limit the current to 16 amp if I remember well, but I don't understand why the controller stop instead of just limiting to 16 amp ... By the way does anyone know how long can a battery supply it's max discharge rate ? Because it could make a big difference for the uphill part and make the shunt mod more interesting ....
Julien
