Bike Repairs
Fleabag
Oct 2, 2021
Hi everyone.
I took my Woosh Gran Camino into a local bike shop for some minor work on the gears and they said they couldn't work on it at all due to it having a throttle and being a legal grey area. Anyone else had this? Am I going to get this everywhere?
Cheers
Waspy
431
170
Remove the throttle and take it back there. Tell them you've seen the error of your ways and you are a born again good citizen and will definitely not be refitting the throttle after they have repaired your bike. :D
8,529
Point out to them that it is legal as it isn't a twist and go meaning you don't have to pedla. Tell them they needs to get their facts right as it is a pedal first option and the throttle is legal as once one stops pedalling it then becomes inactive.
Reactions: Bikes4two
8,529
Also simply tell them the bike was sold as and conforms to EN15194 EAPC rules.
3,226
If the OP had the other type of throttle ie active all the time: Would splicing in a switch onto the throttle cable, to be switched on manually and only while pedalling, make an illegal throttle legal? Would that even work? "See? It's switched off orificer!" I've got a slightly faulty throttle I could try this with...
8,529
No throttle switches allowed so illegal.
Reactions: guerney
Bikes4two
1,001
431
Havant
Hi Neal, I've seen discussions on this forum about when a throttle can and cannot be used but not having a throttle myself, I've not really taken more than a passing interest in the subject but having seen this post and in a recent discussion about throttles with my local club mates, I'm now wishing I'd paid more attention previously!
  • So, a throttle that is active and can power the bike all the way to max speed WITHOUT pedalling, is known as a 'twist 'n'go' and is currently illegal in the UK and EU unless individual 'Type Approval' has been gained- so yes, I've got that.
  • An exception to the above is if I understand this correctly, is that a means to activate the motor up to 6km/h without pedalling is ok, a mode often referred to as 'walk assist'
  • Now to the bit I'm unclear on and that is the legality of having a throttle that can power the bike all the way to max speed providing you are turning the pedals - would you (or other forumite) be so kind as to provide a link to a governement or other authorititive source that clarifys this please as I for one and no doubt the OP will find this useful (and I'll be sure to book mark it too!).
  • I have looked through EN15194 on a number of ocassions but the only reference to this subject I've found is in the pic below.
Many thanks
56912
Reactions: nwbkr
8,529
UK law simply states twist and go EPAC or ebikes aren't allowed unless registered as such. A pedal first activated bike in definition means it's not a twist and go.
One reason why Wisper have the Le1A class registration option for their bikes, allowing full twist and go and legal.
Flecc can likely give a better understanding of the situation but in my eyes I would have no worries if I were to operate with a thumb throttle .
Any how the future for UK EAPC will be cleared up when 500w and twist and go will be allowed no the UK mainland as the DFT realise that 250w is not enough power to encourage the less able to get about of for cargo usage.
16,861
Hi everyone.
Cheers
Is there another bike shop not too far away? And what is it that you need done? In case of difficulty finding a friendly bike shop, please email support@wooshbikes.co.uk we will put you in touch with someone who can help.
Deleted member 16246
Any idea when these consultations and the changes will be finished and decided?
My Bafang 250watt BS01 has a throttle that works all the way to max speed in level 5 PAS, but not at other PAS levels. I could easily remove the throttle if I thought there was any realistic chance of being pulled over, but I don't think there is since I am living in a pretty empty rural area and only ride on empty roads. You rarely ever see the police at all around here.
I would be reluctant to remove the throttle because of its effect in level 5 PAS on the power output. I get about 500 watts showing on the screen monitor at max PAS level if I use the throttle and about 250 watts max when I don't use it and just pedal. The extra watts are only temporary, but are a godsend on steep hills.
The level of throttle assist released at max PAS setting may be down to what was arranged by the guy who built the bike for me and his use of software and cable to programme it. I have no programming cable and have never looked into changing it.
3,226
My BBS01B was so badly set up, I almost sent it back demanding a refund. What really helps on hills and everywhere else, is setting "Keep current" to 100%. My throttle-less BBS01B conversion eats hills for breakfast.
Software for PC:
Android:
56913
Reactions: Az.
3,226
Would a small mechanical gizmo to phycically connect and disconnect the thottle connector, to only be used while I am pedalling, be construed as a switch? It'd beat the rozzer lift back wheel press throttle test.
Either that or making a little electronic gizmo monitoring speed via an additional external PAS disc on my BBS01B, automatically enabling and disenabling the throttle as legaly required. Or a GPS speed tracking phone app enabling and disenabling the throttle as legally required via bluetooth? Luckily I don't need a throttle, but it does seem many do - perhaps someone will make a throttle legalising retrofit kit for hub motored bikes, Bafang mid drives etc. if there's sufficient interest?
3,133
Many thanks
It's not difficult. Throttles are not illegal. Th only relevant rule is that the power must stop when you're above 6km/hr AND you stop pedalling. As long as you're pedalling with or without effort, you can have ten throttles to regulate the power or speed.
8,529
Consultation is open unitl 25th April 2024.
One assumes if successful they would like to push it through during this parliament.
portals
621
180
I stll thnk it's a good idea
Hi everyone.
Cheers
Crikey, that's kinda pathetic if you were just looking for a mechanical repair, name and shame them...
When I built my ebike from a kit (dinner plate, I'll leave it there), I took it to local guy who's shop is less than 1/2m from where I live to check over bike in case I'd messed up badly somewhere mechanically.... He made cpl faces at the hub power however was happy to work on the bike's mechanics (not any electricals), and chat, he got some sales from me too (new black front wheel/tube/tyre to match rear rear hub), new v brakes, stand and few other odds/ends).
For anyone in Glasgow area, If you have an ebike then take it to him saying the old guy with the dinner plate ebike sent you ;-) Shop is call Bike Love on Garscube Rd.
30,581
As Saneagle has said above, there is no ruling for or against throttles, only on whether pedalling is taking place to permit power, so no clarification on throttle use during pedalling is required.
portals
621
180
The mods should create a sticky withe a list of local bikes shops that are happy to deal with ebikes, would save some ppl a wasted trip and probably become quite a useful resource if it's kept up to date.
