bike mirrors
billyboya
1,136
90
73
uk
Hi all just wondering why every wing mirror I use on my bike I can never get to see whats behind properly, as for the left one its a waste of time, and my main right mirror all I can see is my arm. I have to place my arm on middle of handel bars to then see whats behind, I have adjusted it many times but no good
any suggestions whats best wing mirrors to buy. I cant have those handle bar ends mirror as I have a throttle on my bike
3,226
I use both Zefal Dooback II and a Zefal Cyclop end bar mirrors, and they do a good job of not showing me my arm... but because they're concave, objects are closer than they appear - this has led to frantic beeping from drivers when I'm changing lanes etc. Also makes those mad lycra guys overtaking harder to spot, during the day.
3,226
Can you fit a thumb throttle? One of the hub magicians might be able to advise.
3,133
Most of the Zefal ones are good. I prefer the Zefal Cyclops because of the way it folds when you want to park or get through a narrow gateway.
You can use bar-end mirrors with a throttle. You just need to cut a hole in the plastic that covers the end of the handlebar, or you can cut off the end of the throttle. All the workings of the throttle are at the other end, so you can cut off 2" if you want or convert it to a half-width throttle without compromising the function of the throttle.
billyboya
1,136
90
73
uk
Wont that mess up the throttle, by cutting into it. I will have to take a look how the throttle is at end
billyboya
1,136
90
73
uk
Yeah that would help, but I didnt want to mess with electrics, It would solve my problem then if i had a thumb throttle, I will see if i can remove throttle etc, and see about a thumb one
portals
621
180
I have a zefal dooback grip one on RHS, works OK but is easily knocked which isn't a bad thing, I find it more useful than not so it's still on bike.
See this thread:
thelarkbox
1,203
365
oxon
look at the 1/2 grip throttles too perhaps they also allow easy fitting of end of bar mirrors.
be mindful tho that end of bar mirrors can pop off with a slight graze so buy cheap and buy a few.. my nice expensive 'oxford' branded version lasted a day.. ali express specials (check the 1.99 deals) seem to last longer..
Reactions: Teejay
Benjahmin
2,590
1,746
70
West Wales
Both our bikes have these:
Convex mirror gives a wide view field. They fold easily on friction hinges. Fits on left or right side.
My bike has a half throttle and the wifes has a full throttle. As Saneagle says, just cut the end out of the grip, this allows you access to the handlebar end that sits inside the rotating part of the throttlr grip. It will not affect your electrics at all.
3,226
I remember you were nervous about your warranty when I suggested cutting through the end of the your twist handle throttle of your brand new Soodoo bike before, but if I recall correctly you bought your bike almost a year ago, warranty is nearly finished, and you may feel less nervous about doing this now?
billyboya
1,136
90
73
uk
yes thanks all I will check my throttle when i get the time as been so busy with family things but thanks all, and yes I will most probabaly cut part of throttle off at end, as mirrors i have on handel bars are as much help as a fly on a cows arse PMSL. thanks guys anyway for helping will let you know later how it all goes
jokskot
159
47
76
I have a mirror on the down tube which gives excellent visibility during the half cycle that the right leg raised. The mirror is carefully placed so that it is not hit by my thigh during mounting/dismounting or my knee when pedalling.
Just a quick glance down is enough to take in the state of the traffic behind.
8,529
I use Briskmore folding bar end mirrors on three of my bikes, the Roadrat, Ute and the gravel bike. No issue with veiws from any of them.
billyboya
1,136
90
73
uk
a picture would be nice to see that
Well I took a image of my right handle bar throttle and i see at ends the looks to be a allen type slot but i couldnt seem to fit a key in the end will try some more keys but the whole throttle is where i have arrowed on the left side grip and where the arrows point to on throttle side all that is included with throttle so maybe if i can remove the centre end bit i can hopefully fit end bar mirror
3,226
Might be this? Probably less wobbly than the insect antenna type, will miss the arm and might show more than your knee?
8,529
They show a nice view of behind when no one is on the bike.
Typical marketing rubbish , that most will over look.
Reactions: guerney
3,226
Certainly looks that way in the photo, but perhaps the mirror is very convex? In which case, again, objects will be closer than they appear, and the cyclist will be wise to take that into account before changing lanes etc. And those insane lycra dudes overtaking will be invisible.
8,529
From the mirror position one will get a nice view of the upper thigh and lower torso, as you know typically on bikes mirrors need to be on stalks so any view isn't interferred by arm positioning or they have to be placed wider out of leg arm range to show a decent longer rear view. No use having a mirror positioned showing a vehicle that is almost on top of you.
Reactions: guerney
