May 28, 20187 yr Hi all. I've been looking for some time for a bike suitable for me. I'm 21 stone and after a bike to hopefully bring some fun back to cycling for me. I have woods round the corner to me so aim to use in there and on the road. A twist throttle would be good along with the pedal assist. It's all pretty flat here (leigh on sea, Essex) but I'm thinking a 250w motor won't be enough considering my weight? So long as the bike looks fairly normal im sure i would be fine with a higher wattage Any recommendations would be great, thanks
May 28, 20187 yr leigh on sea, Essex pop in some time to check out the Woosh Big Bear, we are in Queens Road. http:/wooshbikes.co.uk/?bigbear
May 28, 20187 yr Author pop in some time to check out the Woosh Big Bear, we are in Queens Road. http:/wooshbikes.co.uk/?bigbear I looked at your website but it said don't bother if youre over 20 stone
May 28, 20187 yr I looked at your website but it said don't bother if youre over 20 stone that's just a general guidance.
May 28, 20187 yr bbs hd 1000w tho you can up it in the software. https://www.ebay.co.uk/itm/Bafang-Mid-Drive-Electric-Bike-Kit-BBS-01B-BBS-02B-BBS-HD/332102833566?hash=item4d52df159e:m:mEhDmc__6KyrCBsTZRewK-A strong dh wheels. http://www.wiggle.co.uk/mavic-deemax-ultimate-mtb-wheelset/?lang=en&curr=GBP&dest=1&sku=510951&kpid=510951&utm_source=google&utm_term&utm_campaign=UK_PLA_Components&utm_medium=base&utm_content=mckv%7csKiBb2sU6_dc%7cmcrid%7c67090789502%7cmkw%7c%7cmmt%7c%7cmrd%7c510951uk%7cmslid%7c%7c&mkwid=sKiBb2sU6_dc&pcrid=67090789502&prd=510951uk&pgrid=17507338502&ptaid=pla-127999944542
May 29, 20187 yr riese and muller are tough and sturdy, 140kg is stated. And that's just what's stated I've been torturing something that reccomends 110- for the past 4 months so if you can afford or save up, get something from r+m
May 29, 20187 yr What sort of performance can i expect from the motor at my weight ? Take Leigh Hill for example, you should be able to climb it with a little pedaling. Range: about 40-45 miles with the 15AH battery.
May 29, 20187 yr Author Take Leigh Hill for example, you should be able to climb it with a little pedaling. Range: about 40-45 miles with the 15AH battery. Sounds promising. And what about flat ground? Can you move by throttle alone? Is there any way to remove the 15mph limiter?
May 29, 20187 yr Can you move by throttle alone? yes, but the new law does not allow using the throttle alone, you have to pedal a bit every 30 seconds or so. Is there any way to remove the 15mph limiter? You can, but we do not support de-restricters.
June 16, 20187 yr Author I've just seen on the Woosh site the big bear isn't suitable for off road. Are there any other suggestions ?
June 16, 20187 yr the Warrior is good for off roading: http://wooshbikes.co.uk/2017/fb6/warrior.jpg You may have seen it already in Leigh. The motor is Bafax MaxDrive G330, 48V 12AH battery, range about 35-40 miles. Price: £1,299. A bargain.
June 16, 20187 yr Sounds like you need eMTB. Most use torque sensing middrive motor compared to cadence sensing hub on Bear. You need to test ride a few bikes to understand difference.
June 16, 20187 yr Is that one of your bikes woosh? Would it handle 21 stone? we make bikes for the traditionally built.
June 16, 20187 yr Author we make bikes for the traditionally built. So the warrior is one of yours? Would it perform as well as the big bear up hills and be ok on trails? Do you have any to try out?
June 16, 20187 yr So the warrior is one of yours? http://wooshbikes.co.uk/2017/fb6/woosh-logo.jpg Pop in our shop in Queens Road, it's in the shop window. We try to be discreet, if you see the red Woosh logo on the head tube, it's from us. Edited June 16, 20187 yr by Woosh
June 16, 20187 yr Author Do you have a link? Would it perform as well as the big bear up hills and be ok on trails?
June 16, 20187 yr No James. I only bought a small batch because they are relatively expensive. They don't sell as well as the cheaper fat bikes, but for real off road, you need a suspension fork. The cheaper ones have rigid forks. You can pop in and try out a few if you like. There is no obligation to buy anything.
June 16, 20187 yr Author OK thanks is the climbing power the same as the big bear? I don't know how the motors compare. And they'll definitely cope and the warranty still apply with 21 stone ?
June 16, 20187 yr the sus fork on that bike is cheap and given ur waight it wont be long b4 it is knackered if doing lots of miles off road. you also cant really service them like fox or rock shox but they do cost alot more thus why the bike is cheap in the first place. http://www.chainreactioncycles.com/rockshox-bluto-rct3-solo-air-forks-15mm-2018/rp-prod151087?gs=1&sku=sku551031&pgrid=49334610141&ptaid=pla-425336154939&utm_source=google&utm_term=&utm_campaign=PLA+All+Products&utm_medium=base&utm_content=mkwid|sE3ssYXt6_dc|pcrid|254148898260|pkw||pmt||prd|551031UK
June 16, 20187 yr OK thanks is the climbing power the same as the big bear? I don't know how the motors compare. And they'll definitely cope and the warranty still apply with 21 stone ? the Warrior has torque sensor, you have to put in at least 25% of the energy required. As for climbing power, the Warrior is better because it's a crank drive, with 9-speed Deore derailleur. The Big Bear can only go on tarmac'ed roads. The warranty is not for off roading, if you break something while off-roading, you are not covered. On made roads, yes, you are covered.
