What I was trying to convey, is that there may be poor electrical conductivity due to the battery contacts opening up over time.
Doesn't necessarily have to happen over rough ground, as the poor contact has already occurred over the months/years.
The battery and docking station is pretty plop, and allows loads of movement.
This can cause the contacts of the battery and docking prongs to spark, and melt the surface area somewhat. Then they don't conduct electricity efficiently anymore.
I managed to wedge a piece of rubber into the battery lock, to help prevent the up and down movement of the battery.
Worth a try bending the contacts, but as KirstinS mentions, it may be poorly/old battery cells, or a bank of cells have become detached (internal wiring)
Sorry, didn't mean to say it wasn't worth trying
It deffo is !
Guess just "managing expectations" as my boss loves to say
And as for testing - what do you have the most of ? Time or money - serious question.
Testing the cells well require time and some Financial outlay but you'll learn lots. Most likey end up back where you are now ie you prob have some duff cells !
So is it best to just send for testing and repair at same time now ? Depends on your time vs money vs desire to learn
I hope the cheap fix by Fordulike works. I'm just a little bit sceptical
Check first and if not..... Let us know
Tp explain a littlemore what I mean.
You'd need a bare minimum of a Lipo charger/discharger (say 35 quid for an Imax b6 delivered with psu and a multi meter - 15 quid tops online/maplins/Halfords) to test yourself. Along with time to look at you tube and ask questions here etc... The charging and discharging is very very time consuming with a cheap(but good) charger like the Imax
But that 50 quid would go a very good chunk towards simply having it recelled by someone like Insat.
Over to you !
