I don't have such a large chest to counterbalance the weight, thoughbattery in a rucksack: thats the way THEY do it here on the pics as well:
4kg is hardly noticeable, in a backpack...
Hi Kraeuterbutter, your photo of the lady have given me a couple of ideasbattery in a rucksack: thats the way THEY do it here on the pics as well:
http://www.bike-elektro-antrieb.ch/07_aug/Kabel_01_.jpg
http://www.bike-elektro-antrieb.ch/Bilder/Antrieb_47.jpg
http://www.bike-elektro-antrieb.ch/bilder3/dev_3_4.jpg
for 4kg battery-weight:
inthe other Bromton-20"-Folder with Nano-Thread
HERE: http://www.pedelecs.co.uk/forum/electric-bicycles/1673-test.html
he says: up to 9miles range with 36V BOSCH battery 2,6Ah
when you dismantel the BOSCH-Battery-pack and reconfigurate the cells, so they are very FLAT and can huddle against your body, very close to your budy
cell-weight: ~860g
so 1kg should be doable (schrinkrapping or taping the pack and applying some foam plastic between the cells and your back)
i think 1kg flat mounted on your back should realy not be much feelable
Those are best looking pair battery cells I have ever seenwell well... here from the same homepage:
http://www.bike-elektro-antrieb.ch/07_aug/Kabel_02_.jpg
Man sieht’s kaum – das Kabel...
(the text under the pictures says: "you can barley see it - the cable")
so: when yours are smaller, there should be plenty of room for storeing batteries)
I want to fit a motor to a Dahon folding bike and would like some advice and recomendations as to the best motor, battery, controller for this project. I would like to acheive low weight, maximum performance and reasonable cost.QUOTE]
When Dahon produced their now discontinued electric folder, the Roo EL, they chose the Sram Sparc system (rear hub containing 5 speed hub gear, two 100 watt motors, and the controller circuit board - therefore only two external wiring connections: one to the battery, and one to the on/off/battery meter module on the handle bars).
The motor hub needs a rear fork with 135mm drop-out, and having bought some second-hand Roo Els, I found that the motor wheels transferred easily to the Dahon Speed P8 and the Speed Tr, the steel frames of which I find preferable.
As for batteries I would advise switching the original NiMh cells for Lipos, which having 15% higher voltage when fully charged, give a very much zippier performance, aided by their being half the weight of the NiMh.
It is a pure pedelec system (all processing done inside that rear hub) which I find contributes best to fitness improvement, there being no temptation to coast up hill or on the flat.
