This is to change the motor ratio, not peddle ratio (Is it necessary? I don't know!)Aren't you trying to solve a problem that doesn't exist? Why not just fit a double chainwheel?
I think that if the larger sprocket gear is made smaller, this will bring the larger sprocket nearer to the motor centre.Now that you've drawn it like that, there's another problem. The sprockets are a different size, so their centres from the centre of rotation of the change mechanism need to be different, which then means you need different idlers. Have you drawn it all out and calculated the ratios?
