BBS02B 750w & SW102T
jrumpaul
7
Hi Guy just done a conversion using BBS02B and a SW102T
The display readout for power only ever goes up to 250w
I did buy from AliExpress uk and it was 750w and does have this stamped on the motor
Any insight or help to why this combo is doing this.
Jordan
jrumpaul
7
Hi Peter it has a set 5 levels on this display.
the config tool shows 9 so don’t fully understand that side. First e-bike conversion for me
but on every assist level I see it peak at 250 but never goes above.
Peter.Bridge
1,494
695
Is it increasing power as you increase the levels (does it feel a lot more powerful on level 5 than 0/1) ?
Have you programmed the percentage power for each level ?
jrumpaul
7
Yes it definitely increase can on level 5 can get a solid 20mph.
the percentage on the web config tool did show 100% power for the higher levels.
I’m just finding strange with the readout not going above 250. It does not even go to 251 is a dead stop at 250w
Peter.Bridge
1,494
695
Is it 250 exactly ? That is very strange
If there isn't a speed limit set, either against the level or overall, then I would expect a 48v nominal (54.4v for a full battery) * 24 amps to go a lot faster than 20 mph
3,319
Could you possibly upload the config file for us to look at? Or screenshots or photos of the configurator sections.
Usually "Keep current" by default is 20% on many Bafang BBSXXX motor controllers, 48V X ((24/100) X 20) = 230.4W
Explanations of settings:
Reactions: Peter.Bridge
