BBS02 waterproofing
8,594
If you get the chance try for a refund/send the BBS back and use Woosh, get the tdsz2.
MrMark
67
I have asked them for a refund and I am waiting for their reply.
If they agree this time I would get a hub drive motor since it seems to be more more reliably.
minexplorer
532
93
56
Four Lanes,Cornwall
I got the responce form ecplise. They adviced me to check connectors and unplug and dry everything. So I did it.
But after few short rides motor cut off and does not work. No errors on the display this time.
Also, I have noticed a tugging feeling from spinning the motor backwards that I never noticed before.
I tried to strart the motor with all sensors unpluget but nothing has happend.
I wrote to ecipse again and I am waiting third day for their reply...
I did not open the motor yet because I do not know does it affect my guarantee.
Since motor cut off last time I took everything off my bike and fit my original bottom bracket so I can work like before.
What should I do? Can I open the motor and still be entilted for guarantee?
mark.im sorry to say this,but sounds like you have the same issue i had.the motor randomly dies for periods of time,or cuts in and out using PAS ,when the throttles connected ,when under load,such as starting off from stopped.this has been caused by the un waterproofed throttle shorting the controller and damaging it. the only solution is a new controller.with a waterproofed throttle the bbs are excellent kits.
8,594
Of all my kits the least used and least liked is my BBS01, I haven't used it for about a year.
MrMark
67
I have been told that they need the kit to be send in original packaging which I didn't keep. It was random cartoon boxes I never thought about keeping them. They also told that they need to a test to find the issue.
It seems like I am staying with bbs but there is still no answer how to fix the motor.
8,594
Probably a new controller needed.
minexplorer
532
93
56
Four Lanes,Cornwall
the motors not broken the controller is.I sent mine back,cost £4 2nd class recorded.Eclipse fitted it to another bike.tested it ,confirmed and replaced. Was pretty straight foward.They replaced the throttle before that and the bus cable too because one of the brake sensors had stopped working. I found them reliable with warrenty issues.
MrMark
67
Finally my problem has been solved!
I received new controller from eclipse after nearly two weeks since I let them know that the motor is not working.
Everything works fine by now.
I must admit that they solved the issue but it took them a very long time.
While I was waiting for a new controller I have started some waterproofing of my kit.
I have used Dielectric Grease for all connectors and sealed them with a tape.
I have also applied a liquid tape at the butt-ends of battery cables.
Is there anyting else I can do to make my motor waterproofed?
Should I do something with control panel or screen?
minexplorer
532
93
56
Four Lanes,Cornwall
Yet another customer cost lots of hassle Bafang,another £80 controller ruined! An all coz of the shoddy throttle waterproofing, that would take your factory staff 10 seconds with a blob of silicon to remedy!!!
Reactions: jarob10
