BBS02 battery charger
4,211
and the apparent inclusion of a cooling fan, which seems to be a desirable feature to look for in a power supply.
The only chargers I had problems with were the ones with fans. The ones without fans don't get hot, so they don't need fans.
Reactions: guerney
3,410
6,733
its only 30v 5a you need one thats 42v or more like a lab power supply
Reactions: guerney
3,410
6,733
just double check what you set it to it might say 42v but might be 42.05 with a decent multi meter
Reactions: guerney
6,733
ans as you are here i tried to change the amps on my m8s hd and it is locked at 28a and is using way more batt that his other bike set at 30a ?
it has been sat in a box for well over a year but it is potted so cant check anything seems his controller is falty
3,410
AFAIK there are different current limits on HD controllers: 28A, 30A, which might be altered by complete firmware replacement?
Was the battery sat in a box for a year? If so maybe it needs a balance charge? And a battery boffin. Do both batteries contain the same cell type, are the batteries the same capacity?
6,733
no he has 4 batts its the controller but if it is firmware locked then it does not explain the batt usage as should be less not more o_O
3,410
Do a bench test and measure the amps drawn from the batteries?
6,733
it does the same thing with all 4 batts less amps and less range like a sort of short or bad connection on the controller.
3,410
Did he fit the controller himself? I've never seen a HD, but if it's as cramped as the BBS01B, it's easy to pack the wires too tight when reassembling, risking bullet connector connections. Controller and motor should be easy to push together, not forced, rearrange the wires if not. But of course it could be some controller component failure, in which case you'd need help from someone who knows how to test and repair BBS controllers.
6,733
the cables look fine but i cant see past the potting so could be duff from the factory fkn things are 135 quid now :oops:
3,410
Your mate might have to start a thread about how to test and repair his BBSHD controller. Cheaper. @Topdonkey managed to pick out the potting and replace MOSFETs on his BBS02:
6,733
i said just swap the controllers over but not opened his old motor so not sure what version it is as the connectors are different.
the new motor never even had a gasket fitted to the controller :rolleyes:
3,410
Water ingress causing problems perhaps? Maybe dry the controller and the motor bullet connectors? I recently managed to dry out my Canon 650D camera using these dessicant silicone beads, time'll tell if permanent damage has been done to the camera. I should have waited a few weeks and bought the 700D, which is the same camera but weather sealed :rolleyes:
Geenbikekit left out the gasket when I bought my spare controller, but they made it right by sending one two weeks later, but it's not rubber. I'll use some heat tolerant silicone over it, to seal.
6,733
he should of tested it when he first got it, took me 5 years to make him get one in the first place :p
3,410
My spare controller has been sat in a box for about two years. I don't know if it works, but BBS01B controllers are cheaper :cool: Although about two weeks wait of course, for a new one.
6,733
last time i looked they was like 75 quid but ppl can shunt mod them to 50a for 60 quid :p
6,733
you can shunt mod even bosch motors problem is the batts as mine are limited to 20a discharge and no way atm to mod the bms :confused:
but if you do this and the batt can only do 30a discharge means fire check the rc lipo vid ;)
