Has anyone here successfully fitted a BBS01 into this bike? I've seen a large frame used one that Im considering. The bike ticks two boxes for me, 29er with a wide range cassette. Although the top tube is straight Im not sure if there will be enough room for the battery to fit in there. BB is 73mm wide but just described as a square taper sealed bearing so Im not sure if the bottom bracket on this bike is suitable ie with the correct threads. Any comments welcomed.
