Battery unbalanced
mike killay
3,012
1,629
Not sure what you mean by a "small short circuit", a high impedance leakage path perhaps? This can occur but the BMS should rebalance the cells if it's given the chance by every now and then by leaving the charger on for a few hours after it indicates that the pack is fully charged.
Now this is directly in contradiction of what |Andy Mat has posted
2,835
General opinion seems to be that it is a good idea to do this 'every now and then' (as quoted) , but generally to try to stop charging as soon as the light goes green (or even a little before if you can estimate when that might be and don't need to squeeze every last drop out of the charge).
SwampRodent
34
9
"2. Are you giving the BMS chance to balance the cells for a few hours after the pack is fully charged? This needs to be done every so often, not necessarily on every charge."
OK that kind of confirms my suspicion, I'm not leaving the charger connected long enough for the BMS to balance charge the cells, then once the cells are to far out of balance the BMS trips and no further charge can take place.
My home charger terminates the charge at 200mA, this is obviously too early, and the work charger is on a timer which again turns of too early so I think this may well be the root of the problem, hopefully this might be what's happening with Mike who started this thread.
Reactions: ebiker99
Baboonking
147
Watford
If the BMS needs 2 weeks to balance the cells it's faulty.
The BMS could be working exactly as designed but still not be capable of balancing the cells except over a very long period of time. For example
Take a 36v 15AH battery pack with this commonly used bms https://vruzend.co.uk/products/10s-36v-15a-lithium-battery-bms-balance-function-18650-li-ion-uk-seller-stock it has a balancing current of just 40ma.
Now imagine said battery pack has been left in a damp garage for 6 months and corrosion means there's a higher self discharge rate for one of the parallel groups, or maybe through bad luck one of the cells happens to have a higher self discharge rate from the factory. So one group has only 1ah left whilst the rest has 14ah.
The owner then puts it on the charger and it appears to finish quickly because most groups have only 1ah to fully charge. How long would the owner have to leave the battery on charge to allow the BMS to fully balance the pack?
The BMS needs to add 13AH and can only balance at 40ma, so 13000/40 =325 hours or 13.5 days to balance the pack.
Deleted member 25121
The owner then puts it on the charger and it finishes quickly because it only has most groups have only 1ah to charge. How long would the owner have to leave the battery on charge to have a fully balanced pack?
I'd be surprised if the BMS was able to balance cells that were that far out of balance.
wheeliepete
2,047
757
Devon
Your pack construction is a little unconventional with uneven parallel strings of cells. I'm wondering if this is having an adverse effect on the even discharge/charge cycles. I only say this because if we assume all cells are good and you have no dead/dying cells in your pack, then inbalance is unlikely to happen. What are the voltage readings on each parallel string?
SwampRodent
34
9
Electricaly the parallel strings are even, there are 5 cells in each parallel group but physicaly there are 10 cells in a couple of the cell holders.
I only have voltage measurements from taking the battery off the charger, when I balance charge the cells I charge the pack to 42.0V, then wiat for the current to drop to about 1A, that way I don't have to spend to long charging individual cell groups as this can take up a whole weekend.
The voltage of the 'good' cells would be 42.0V (42.2 ish if the BMS has tripped) and the 'not so good cells' 4.05 - 4.15V. When I balance charge them I try to get the charge current the same on all cells, the 'good' cells might be drawing a few mA, if I can get the other cells down to about 250mA the bms appears to be happy, by this time I've run out of weekend so can't get the charge current any lower which may be something else causing the issue.
wheeliepete
2,047
757
Devon
Ignore everything i said above, I was looking at your pack as 4P and that you had cable/braid linking the uneven strings.:rolleyes:It's no fun losing your w/e to battery balancing, done it a few times myself. o_O
SwampRodent
34
9
I know what you mean, I often spend the entire weekend maintaing / repairing my ebike just so I can get to work on a Monday morning :)
