Battery Meters
30,844
Thanks for the reply, but I wondered about a bench type battery tester.
Do some suppliers use these.
I don't know offhand if any suppliers use them. The trouble with sealed lead acid types is that only a voltage or capacity drain test is really possible, testing of individual cells and electrolyte specific gravity isn't possible. A multimeter can check the voltage and the performance on the bike is an adequate capacity drain test so any other kind of bench meter seems to have no point
For the fullest information you could use an expensive Cycle Analyst or Watts-Up meter of the kind referred to within this thread, but I'm not sure what you want to achieve here?
daniel.weck
1,229
