Battery charging 101
joelectric
145
93
Motherwell
Sorry before I could finish yesterday,s post I was called away.
The battery voltage when the indicater changed to green was 53.7 v.
But the best indication was the built in tail light which started flashing rapidly, it's bright enough that I can see it from the house. It looks like I have Xmas lights in the shed.
I am a happy bunny.
Toodlepip
Brian
Check the voltage from your charger as well, these have been known to fail. The Charger should read 54.6v as well.
16,962
Please uplug the charger soon after the LED on it goes from red to green.
Batteries are most at risk of deterioriation when it is completly flat or completely full. This is because the charging process moves Lithium from one electrode to the other. The battery is most vulnerable when one electrode is at maximum volume and the other at minimum volume. Chargers are more at risk when left on green (not charging) for a long period as the output voltage is at it highest.
If you don't use your bike in the winter, keep the battery at about 50%-70%, 3 or 4 bars on the LCD battery meter.
Reactions: Bikes4two
Brian55
15
73
Teesside
It,s getting closer.
It,s too cold, wet and miserable to take the bike for a run, so I just ran the motor on the throttle indoors and topped up the battery a couple of times. It seems very encouraging.
Toodlepip
Brian
cyclebuddy
1,644
773
Beds & Norfolk
Please uplug the charger soon after the LED on it goes from red to green...
Chargers are more at risk when left on green (not charging)...
As I understand it, the OP's battery is new and likely been sitting in storage for some time since manufacture before being first used.
All the charger LED turning to green means is that the battery is drawing below (typically) 2-300mv. It's still topping-off/balancing for some time thereafter. The only way of really knowing is to measure current draw, but IMO all the OP is doing here is getting stored cells back into balance, which is a good thing.
16,962
His battery was manufactured last October. I supplied it to Brian. There is no need to do any balancing.
cyclebuddy
1,644
773
Beds & Norfolk
All of my five 36v e-bike batteries (2 x Fiido, 2 x Phylion*, 1 x TranzX*) continue to draw (typically) 18w once the charger LED turns green. It takes another 0.5 to 1 hour before current draw drops below 3w, which is, I'd assume, when balancing has actually stopped?
*These too are Sans chargers.
16,962
You only need to rebalance if the battery behaves abnormally.
cyclebuddy
1,644
773
Beds & Norfolk
I charged the battery until all the lights on the battery were green, then kept on charging for another 4.1/2 hours.
Post #18
OP Post #23
...so I just ran the motor on the throttle indoors and topped up the battery a couple of times.
Which shows a rise from 53.7v to 54.4 v. That clearly demonstrates the OP's battery is continuing to balance after the LED first turned green.
SANS own specs say the LED turns green when current draw is less than 300mA (although there are several technical adaptations of the same Sans branded charger). That doesn't mean the battery isn't still charging/balancing, just that it's generally in the range of the battery being "near full", not necessarily absolutely fully charged or balanced.
Measure the Sans charger output yourself... you'll see.
16,962
There is nothing wrong with his battery, it is just a new kit. Give Brian a bit of time to understand what's what and find his own ways. You guys tell him to try various techniques, which address problems that aren't there and can cause accidents.
8,589
Toodlepip
Brian
That's looking a lot healthier now Brian and almost fully balanced & charged, your meter also may be 0.2v out unless one can check it against another known source.
Now you know that it is the charger one has to wait for the Green light to switch and not the battery LED's you shouldn't have issues again.
Reactions: Bikes4two and Woosh
