Battery capacity drop
Like this please. All 10 cells with the two connectors unconnected, so 10 results.
Khumarahn
42
Here they are:
>0.3 MOhm
>0.3 MOhm
>0.3 MOhm
>0.3 MOhm
>0.3 MOhm
>0.3 MOhm
~80 KOhm
~56 KOhm
>0.3 MOhm
>0.3 MOhm
Clearly something is wrong, but not the result I'd have expected. There's no solder bridging those pins at all is there, where you unsoldered the daughter board?
One last thing to try before passing judgement. Charge it up and do your discharge test again but use the B- as the negative rather than the normal negative (P-). You'll need to keep checking the cell voltages to make sure none go below 3v.
If it won't charge with the connectors in, see if you can charge between the positive and B- rather than C-. Likewise, you have to check that nothing goes over 4.2v.
The basic idea is to check the cell-pack capacity before deciding on a new BMS.
trex
7,703
2,671
where can he get a BMS for bottle batteries?
Khumarahn
42
There is no leftover solder joining the connector pins...
I'll try to check the cells.
I sent a message to bmsbattery, from whom I bought everything, but they didn't reply yet.
Khumarahn
42
I ran a discharge test, drawing power from B-. I followed voltages on cells, and looks like 10th cell is lagging behind. Below are my measurements taken at several points in time:
* 9 cells at 3.85, 10th at 3.65
* 9 cells at 3.80, 10th at 3.60
* 9 cells at 3.70, 10th at 3.50
* 9 cells at 3.67, 10th at 3.37
I stopped right after voltage on 10th fell below 3, I have taken around 5Ah from the battery by that time.
Khumarahn
42
Many thanks for the guidance :)
Which cells is a good replacement option? And maybe it makes sense the container to something like this?
Khumarahn
42
I am going to try to repair my battery. If it doesn't work, I will buy something decent.
I tried to look up 18650 cells on ebay, and got confused. Do I need protected cells? Can I buy "UltraFire 18650 5600mAh" for 10 pounds and mix them with what I have?
trex
7,703
2,671
assuming you have identified the bad cells. You need to buy new cells with the same capacity. Your battery is probably made with 40 x 2600mAH cells.
Just post what is written on the cells, members should be able to tell you where to get compatible cells.
I do not try to put you off, replacing bad cells does not guarantee success. You could throw good money at it for no result. If I were in your situation, I'd cut my losses and auction the 5AH battery on ebay.
Khumarahn
42
This is what my cells look like. I don't think there's anything written on them except this one line:
trex
7,703
2,671
if you replace 2600mAH cells with 3000mAH cells, they will still work.
There's 40 cells in your battery in 10 groups of four. One group is down, so you need four cells. I think some of the other groups might be not far behind. Ideally, you need to charge up just that low group and continue your test to see how quickly the other nine drop off before deciding what to replace.
Unfortunately, you can't rely on Ebay 18650s because there's so many fakes that are as good as useless - particularly the Ultrafire cells. Another thing, you need cells with tabs welded on so that you can solder them.
If you had a spare BMS, and some good cells, it would be worth repairing, but if you've got to start buying stuff, it's a harder decision. It's going to cost about £50 to fix it, and then the next cells might fail soon after.
I think replacement is a better option.
You need to match the capacity of old and new cells otherwise the BMS might struggle to keep it in balance.
Khumarahn
42
Does there exist a serviceable version of a battery? By service I mean, that it is straightforward to replace bms or any of the cells...
I will look in the direction of the small saddle bag batteries, but this would imply packing a bms and controller too...
trex
7,703
2,671
batteries with prismatic cells are much easier to fix. Fewer cells, cells have solder tabs, BMSes have standard wiring.
Khumarahn
42
would you recommend any particular prismatic cells, and where to get them? And BMS? I am looking for a 36V 10Ah battery.
