Battery 60-80%
WheezyRider
1,690
938
If you check the voltage from time to time, any reduction from that 41.8v will show how much imbalance there is. You only need to leave it on charge for a long time after the green light if the battery is unbalanced.
One thing to bear in mind is that some chargers, eg Yose Power, only output 41.7 V, so the pack will not get above that voltage.
WheezyRider
1,690
938
No way to adjust our chargers or set them other than go from green lights going out when the charger decides.
Don't know how to test the capacity of either battery because my comprehensive multi meter isn't interested in giving a plausible reading.
The charger does not decide when to display the green light. That happens in the BMS. When the input current drops below a set level, the BMS disconnects the charging circuit until the pack is used again and it's voltage drops.
WheezyRider
1,690
938
One way to ensure charging to less than 100% is to open up the charger and see if there is a potentiometer controlling the output voltage. Then you can tune the output to what you want. If not, what you could do is to put one or more ordinary 5A silicon diodes in series with the output. These induce a voltage drop of about 0.5V per diode, so if you want 41V from a 42V charger, just use two diodes in series.
WheezyRider
1,690
938
Once the green light comes on, no more current flows into the battery, it is no longer balancing. The BMS disconnects the charger from the battery, hence the green light.
georgehenry
1,456
1,274
Surrey
The thing that worries me from what you say is that the battery is supposed to be new, when it aught to be delivering its best performance.
I would consider trying to get it replaced from where you bought it.
The last silver fish battery I bought was quite cheap off ebay (under £200 including a charger), so I was not expecting anything spectacular, but it can still power a heavy me and two panniers 10 miles to work at an average speed over 18 mph on my 2011 rear hub cadence sensor bike and will be 3 years old at the end of March 21.
It does sag quite badly on hills ( dropping to 1 bar showing on the display before recovering after the hill) but does not cut out.
I start my journeys with a fully charged battery and am sure it would not take me much further than 10 miles on full assist, but I don't need it to, and can re charge it at work.
Interestingly I re charge my battery in a over heated room and the battery performs better on my journey home.
3,994
The voltage is held on at 42v while the green light is on. That's what provides the charge to balance the cells. The BMS switches off the charging if it uses a separate charge control mosfet, but the bleed resistors will be open, which drains the battery down and switches back on the charge mosfet.
WheezyRider
1,690
938
Hmmm, I'm not convinced about that. To do the balance as you say would still require current from the charger. Even if some excess charge is being bled off through resistors from cells at a higher state of charge, power from the charger would be needed to charge the cells at a lower state of charge. However, once the green light is on, no more current is flowing from the charger.
Have you got a datasheet for a BMS explaining the mode of operation you describe?
WheezyRider
1,690
938
Vfr400 is correct, but be aware some packs balance at less than 100%. It will all depend on the BMS that your battery pack has.
Mine balances from 50% plus, so I never need to charge to 100% to activate the balancing feature.
Can you give some info on this BMS that balances from 50%? Sounds interesting.
3,994
You don't need a data sheet. Put your fingers on the bleed resistors to see how hot they get.
mike killay
3,012
1,629
Are you saying that any unbalanced battery can be recovered by prolonged charging?
mike killay
3,012
1,629
Yes, that's why in many instruction manuals it says to leave the battery on charge for a long time for the first charge.
Thanks,
I have wondered exactly what freezing temperatures could do to a battery, so I placed an 18350 that I use in my vaping pipe in the freezer for a few days.
When I took it out I did not wish to measure any voltage in case it caused damage but let it warm up.
I am now using it as before with no signs of degradation.
Fordulike
3,802
1,538
This is the link to the battery I purchased:
https://em3ev.com/shop/em3ev-48v-13s5p-jumbo-shark-ebike-battery/
The blurb about the balancing is in the description, but if you don't fancy scrolling through to find it, here is the specific paragraph reference the BMS:
'We use a high tech, fully programmable Smart BMS, which is rated for genuine 40A continuous plus, with a programmable over-current trip set to >60A (which is ample for the intended application). With our BMS you can view various battery data, such as: cell voltage levels, temperature, instantaneous charge/discharge current, capacity (genuine SOC, measured Ah and remaining Ah), data log, error indication (on matching LED panel) and it all links to your phone with a continually updated and improved App. Our BMS balances during charging (when charging and when at >50% charge) and therefore doesn’t require a full charge in order to balance. Auto power off function, auto power on and with a pre-charge function (no sparks, so long as the battery is powered off when linked to the controller)'
8,842
Blue tooth or smart BMS are widely available on AliExp and one can fit them to any generic battery pack, on can set the final balance charge limit to which ever voltage they wish. Likewise one can use the dearer Neptune BMS.
WheezyRider
1,690
938
Thanks for that, and for Nealh's info.
I'm currently running a long term experiment looking at how long it takes for cells to go out of balance if charging to 41V (see my thread in the Technical section of the forum):
After >60 cycles, the cells show no sign of going out of balance. It had occurred to me that perhaps the BMS was balancing even at a lower voltage, but according to the spec sheet, it should only balance at 4.18V and above:
39610
However, can this be trusted? It isn't a smart BMS, or programmable. I suppose the only way of being sure is to monitor current flow in the balance wires during charging.
Fordulike
3,802
1,538
Interesting thread, although you probably spend more time testing your batteries, than actually enjoying riding. Tongue in cheek of course :p
I'm a firm believer in buying a pack with quality cells and not cheap out in this area. It makes financial sense in the long run, even if a quality pack can add quite a bit more to the budget.
I think once quality cells have had an initial balance, then there's no reason for them to go out of balance, unless there's some duff cells in the pack.
My last 29E pack wasn't in such good shape after 2 years and the voltage sag was horrendous. I put this down to me fully charging after every ride and leaving it for long periods fully charged.
My latest pack with HG2 cells appears to be going stronger with the same usage, but the difference is, that I don't charge after a ride and only fully charge just before my next ride.
3,994
As I said, you can feel the temperature on the bleed resistors when the bleed transistors are open. You don't need a meter.
Your charge voltage is very close to when the bleed resistors are open, like within the margin of measurement error, so it could be that they are in fact doing some balancing.
WheezyRider
1,690
938
Unfortunately, it's a sealed unit, so you can't touch the resistors:
39621
If 41V is too close to 41.8V, perhaps only charging to 40.5V will be better.
Maybe I'll do that once I've done 100 to 150 cycles at 41V
