batribike diamond pro
stevieb
292
69
does anyone know if it is possible to derestrict this bike?
even if it only gives a slight increase in performance without the abrupt cut out of power at 15mph
apparently it was possible with earlier models by means of the controller but i cannot find anything on this model
thanks
Of course it's possible. You just have to find out how to do it. Go through all the posts on how to to derestrict. One or more of them will work.
8,526
As d8veh say's you'll have to use the forum search facility, its just case of knowing the button sequence and how long to press them. Once you do find a sequence that works remember to put it down on paper or copy a link to save on your e- device.
stevieb
292
69
ok thanks.
i have tried many different sequences but without success.
just thought someone may have already found this out and speed up the process.
so i will sift through the derestriction posts as suggested.
ta.
stevieb
292
69
i think i have now tried just about every combination of button pressing and also searched posts but i am still no further with this.
could it be that some wiring adjustment is required ?.
thanks
You should have started with the wires at the controller.
