Hi Shemozzle,Hi jonathan,
Pedelease also sell this kit they show instructions for setting up the LCD on the link below - they say you need to set parameters P09=0 and P10=1 on the LCD for the motor to run on throttle only without the PAS i.e. the magnet disc and sensor.
http://pedalease.co.uk/index.php?rt=product/product&product_id=13172304
Thanks d8veh. Crumbs, I'd rather not open the controller box I wrestled shut. And not keen on having a throttle. So this bike has to have a throttle no question?You need to have the throttle connected when you switch on, to prevent that.
Thanks D8veh.I have a couple of controllers that made the motor go if there was no throttle connected. Most have a safety system that looks out for that and won't give power until it sees zero throttle. You could try shorting the throttle signal wire to ground if you want to run with PAS only connected.
Hi jonathan,Hi Shemozzle,
Do you know what the setting is for PAS only mode? I've a feeling your technical Chinglish is better than mine, and my effort just now resulted in the bike nearly shooting across the room without any PAS or throttle input ;-)
Thanks Shemozzle - excellent.ElifeBike have now posted the manual in the form of jpg's:
http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2013-CX-G2DJ.24BUM
double clicking on any of the 3 pages will open a new page showing the page in magnified view.
Note if you are going to run PAS only you have the chioce of 3 or 5 speed mode settings via parameter P05
3 speed mode PO5 =0
5 speed mode PO5 =1
