Bafang Display
robwalley
175
30
Gloucester
Don't really understand the size argument. The c961 is 107x58mm and the colour display is 90x60. OK the c961 is landscape but as such takes up more handlebar space.
8,644
Thanks for the info, the portrait version in the pic from your original post just makes it look massive. Probably due to a fact that it is a close up pic.
robwalley
175
30
Gloucester
Moving on, I am trying to investigate the Lishui bluetooth device which is an inline option to have all your controls and display via an app on your phone/tablet. So if I buy an android 7 inch tablet, get Lishui and Ordnance Survey to upgrade their apps to support split/dual screen and.........well you see where I'm going with this.
steveh6883
30
58
Llannon
Just Installed the new DPC-14 colour display and like it a lot, the voltage readout is so much more useful. Anyway I have a good condition C961 if anyone wants one.
Does the C961 have a standard clock/time display? need to know if am going to be late for work or the train when commuting
[EDIT] Never mind - have just found a video from California e-bike on setting the time display on C961 - need to find out now if I can swap out the crappy LED PAS display on my Carrera Crosscity for one of these - looks like the connectors are the same and the motor is Bafang/8Fun 250w (rear hub drive) not sure about the controller though as it is sealed inside the frame
I would be interested in your old C961 if I can find out if it is compatible
17,034
they are not using the same protocol to talk to the controller.
You can't replace a LED display with an LCD.
The LED display uses analog system, LCDs use UART, and each brand of controllers has their own protocol.When I choose an LCD, it has to be programmed specifically with the correct protocol for the bike's controller.
Reactions: D8ve
robwalley
175
30
Gloucester
Sorry, been on hols, local bloke already took the Display unit.
