Bafang bearings replacment
6,592
if he has the parts you could get it back in 3-4 days but imo it is going to cost over 100 quid for parts and labour + vat.
Reactions: guerney
3,307
...then it'd probably be another £100+ for nylon gear replacement = £200+ which isn't all that far off buying a new motor... on the other hand attempting to do it myself is a matter of tools, time and mistakes. But it aint time yet, thank fsck.
Gilk
11
Shardlow
Ok its all back together again:) The bottom bracket bearings had gone, well the needle roller ones had. The bottom bracket has 2 needle roller bearings and 2 caged roller bearings. Only the needle rollers has gone. I got the needle roller ones 'off the self ' from a local bearing company for about £10 each, but could not get the seal as its a very odd size. Had to get the seal from china via ebay, for £7, as the only one I could find in europe was 16 euros and 33 euros postage. The only problem I found was that the tube, that holds the bottom bracket, needs a little heat to both nock the old ones out and put the new ones in, not too much as there is electronics near and you dont want to melt the solder.
Andy-Mat
2,214
562
78
Heating up is very common with knocking out & in, some bearings. Using a gas torch can be dangerous for both insulation and solder.....
Just to be safe, I usually use a hair dryer on hot, and its usually enough.
To further be safe, with wiring I hide it behind aluminium foil or completely remove from the area, when I can...
Well done, and if it ever needs to be done again, you know how!
You may have also helped some people here too!
Andy
jimriley
607
405
When fitting the new bearing stick it in the freezer for a while to shrink it. Less heat needed in the casing then.
3,307
Would that make your balls brittle, for a time? Would your balls shatter if used before they warmed up? o_O
Reactions: jimriley
3,307
Are all bearings of a certain size equal? How is ball strength defined? What should one look for, when selecting new balls for Bafang motors? Are some ball types better than others? I know they use frictionless ruby balls in some watches.
Reactions: jimriley
jimriley
607
405
If your balls are red it's time to worry.
Reactions: guerney
3,307
Reactions: jimriley
