Bafang 36v or 48v BBS01b 250w mid-drive full kit - lowest price ever? - £230 inc. shipped from UK
Was browsing Aliexpress and stumbled on this deal. Already run this kit on one of my bikes, but at this price, I decided to buy one as a spare, or for a future project. I purchased my last kit from this seller, and no issues, so was comfortable buying again. Shipped from their UK warehouse, mine just arrived 4 days after ordering. No duty/tax etc to pay.
A few conditions to get this price, (although still the best price by far even without fee free credit card and topcashback)
1. go through topcashback.co.uk, sign up if you haven't already got an account, they offer 5% cashback with Aliexpress. Once clicked through from Topcashback..
2. replace URL with https://www.aliexpress.com/item/32976874713.html? in browser
3. Select options required (500C-H display), and either 36v or 48v version, and select ship from China
4. Apply discount code 8AESELETED19 at checkout ($19 discount)
5. Also pay for the item in $ using a commission/fee free credit card.
This price is ONLY for the full kit with the 500C-H display, everything you need (bar a battery), all other display options are much more expensive. The seller ships from the UK despite selecting China, mine delivered by DPD. Plenty of freebies included in the kit, including Bafang install spanner, headlight, crank puller tool etc.
Hope this helps someone
  • Replies 55
  • Views 12.9k
Some sellers advertising dispatch from China do seem to send from the UK - I ordered two Bagang headlights from Junstar via Amazon recently, fully expecting to receive them within a couple of weeks, and they turned up two days later. If they advertised UK dispatch, they'd make far more UK sales - I wonder why they don't?
Edited by guerney
Interestingly the 48v one is also listed as 250w and appears to be 15a as well.
I thought the 48v version of the bbs01 was rated at 350w, or did they do a 250w version ?
The 15a at 48v is the 500watt version with a legal 250 sticker but not engraved correctly
Egroover can you work your magic and find a 48v 250w Tongsheng at those prices ?
The best I have found is one for £319.
Seems to be plenty of deals on the 48v 500/750w version (pswpower etc), but not so with the 250w version, enerprof.de seem the only resonably priced supplier which is probably what you have already found..will let you know if I find a deal
Thanks egroover, yes I did see the enerprof ones and also a china uk warehouse seller, but none at silly low prices like the BBS. Until you posted that one I wasn't aware of the 48v 250w BBS01.
The model i received was sold as bbs01 250watt but is a bbs02 48v 500watt model but the sticker in the box as a free gift is 36v 250w
What does it's engraving say? Did you get it on Alibaba from Greenenergy?
Alternatively you could buy a 250w 36v TSDZ2 from PSW Power, shipped from their German warehouse (no additional taxes and delivered in around a week) for around 320 USD. It is the same motor as the 48v one - you just need to get a handle on the Open Source Firmware and run the Configurator and set the voltage to 48V - job done (if you're into that sort of thing :rolleyes: )
Sold on DH gate the engrave shows as bbs02 500w cost £345 box re - seller does not have clue what contents in the box
The 36 v tsdz2 at 20 amps should fry an egg quickly :eek:the controller does not have much of a heat sink only an air gap inside the case check the ES thread before committing [hated the 36v 250watt version]
[ATTACH=full]44543[/ATTACH]
How on earth did you find this deal?!?!? It'd be stellar if it works!
What's the difference between "Brake Lever" and "Brake Sensor" options? I thought brake levers contained sensors.
brake lever (sensors integral) for cable brakes , brake sensors for Hydraulic.
This is soooo tempting! I've been thinking about getting a much better donor bike with more room for double chainwheels, but I can't for the life of me think of why I'd want to go any faster anyway - my normal 20mph is scary enough... It's youthful habit probably, and now long since inappropriate. Also no longer survivable lol.
.........The 36 v tsdz2 at 20 amps should fry an egg quickly :eek:the controller does not have much of a heat sink only an air gap inside the case check the ES thread before committing [hated the 36v 250watt version]
Hi Peter,
  • Out of interest, why did you hate the 36v 250w?
  • The ES forum has quite a lot to say about the TSDZ2 heat problem and different folks have fitted temperature sensors and additional heat sinks to help mitigate the issue.
  • What is never clear though is where those suffering the heat problem are (in terms of their local climate/temperatures) and what power they are using the TSDZ2 for, e.g. 36v 250w or 48v 750w and indeed how much 'assist' is being asked for.
  • As a recent adopter of the TSDZ2 as in the last 3 weeks) I shall be very interested in how warm the motor gets in the UK summer - do you have an experiences of this?
  • Personally I've set my max current at 15A which works for me and wil obviously lessen the heat buildup
  • If of course heat buildup becomes an issue in our UK climate, then running at 48v might be a useful step before faffing about with a temperature sensor and heat sinks?
Any views anyone?
The 36v 250w out of the box lacks power and labours when pressed on a hill ,far less assist unless in turbo and pushing hard on the pedal the power band is narrow mine drew very little current about 8 amps 13 max it ran hot if the outer case is hot the controller is to hot to touch
The 48 v at 18 amps is better but still makes to much heat in the summer it got very hot had to stop and cool down .Even my special order from ECO cycles fat bike 120mm bb motor at 20 amps got far too hot even when running the pre loaded os software, it could not handle the 30 inch dia tyres even with a smaller chain ring Found the 750watt rating to be more like peak power and do not mention the decline /variable build quality that was the final straw for me
Just out of interest are the tongsheng's engraved like the bafang's or do they just have a sticker ?
Just noticed the discrepancy in the price when looking at the new 500c-h display.
If you sold the display and other bits in the kit, you'd probably get about a £100 for them,meaning the bare motor costing you £130..happy to buy as a spare motor to swap out when my current one wears out as the parts alone would be way more than that
its a sticker :rolleyes:
[ATTACH type=full" alt="44561]44561[/ATTACH]
That's pretty poor really and no wattage rating noted either, tbh it could be any of their motors so no way of proving either way whether it complies or not.
Without the cashback: It even quotes the same price of £267.57 when you select "Ship from UK" - that is absurdly cheap! The seller I bought my kit from originally, recently quoted me £425 for a bare bbs01b motor and a spare controller, with no accessories. Is there something wrong with those 500c-h displays, or have they got a glut of them I wonder?
Edited by guerney
I was hoping this is where the 750W motors mis-engraved as 250W were sold... ;) I've never been stopped by the cops, but an engraving should be useful - there are CNC engraving machines available for less than £300, or maybe I could hash a really horrible little engraving job with a stencil and a dremel...
I think it's just a glitch/misprice by the seller, all the other displays kits are much more, it's even less than the bare motor price !. If you select UK delivery, it adds VAT at the checkout, choose China shipping (VAT paid by seller) to get the cheap price. As I said, ordered mine last weekend, delivered Wed from the UK warehouse, they ship from their nearest warehouse regardless of where you select
