Badass Box v3.4
The Bear
517
179
53
South Yorks
If yours are dead too get some from Poundland or similar or eBay, the speedo and the sender both take a CR2032 you can get pansonics from there 4 for £2 where some rip off places will charge you a fiver for one.
Cripes!!!!! Asda charge £7.50 for a pack of 4. Good job I ordered a pack of 4 Panasonics from eBay for £1.97
Reactions: Rich_uk
6,691
8,734
Strangely on some items SW is no different them the rest of us and likes economy / value on small replaceable items.
20 cells for under £3 is a great bargain if they are genuine .
Reactions: Rich_uk
The Bear
517
179
53
South Yorks
Sadly the bike computer is going in the bin. Even with fresh batteries I can't get the unit to turn on properly. The display flickers at random and then turns off. Tried it with various batteries but without success. Good job it was cheap.
The hunt continues...
Rich_uk
134
49
59
West Midlands
Not sure if mines ok as I haven’t used the bike for a while with this weather we’re having, don’t bin it though open a return case, as it’s faulty the seller has to pay the return postage so he’ll likely just give you a full refund without having to return it.
Reactions: The Bear
The Bear
517
179
53
South Yorks
Thanks, I've just done that and the seller has refunded me :)
Reactions: Rich_uk
speedy41
35
48
Hi All,
So do we think the speedbox may be the better option? Im in the same situation, I have a bad ass box but hate that it doesnt display the correct speed. Is the speedbox worth a go?
Cheers
Adam
Rich_uk
134
49
59
West Midlands
Hi All,
Cheers
Adam
Yes definitely, get the speedbox, and sell me the badass for my other halfs bike :D
Seriously though like soundwave said I barely look at the speed anymore, it used to drive me crazy too but you get used to just doubling whatever the speedo says.
Reactions: soundwave
6,691
if you can look at the display you are not going fast enough :p
speedy41
35
48
True, so how do we go even faster soundwave?? 250 watt haibike im on. Can the motor be upgraded?
Thing is doesnt it skew other stats as well though? I just want to see how fast im going... On private property of course.
6,691
its not a 250w motor under the 15mph limit or with a dongle it will pull max power and its more like 8-900w.
thus why you can fly up steep hills but on the flat it is the gearing that you need to change.
so a 18t or 20t front sprocket is the way to go but for max speed you need to spin the cranks at 120rpm.
if you are fit you can hit 40mph with a 20t at the front but dont expect this as avg speed and in bursts at max crank speed.
Zlatan
8,086
4,290
The stat it skews more than anything else is the range...
With mine fitted I can average 18 mph (without about 13).Its only around 14 miles and without dongle I have over 40% battery left. With it under 5..
Took mine off.. It did mess speedo, mileage and trip up.. I used GPS on phone when dongle fitted..
Made me feel rather guilty averaging 18 in national park. Was about 7 in morning though... Nobody in their right mind is out in Derbyshire at that time..
speedy41
35
48
Thanks everyone apreciate all the comments.
