Back wheel puncture
Goryl
88
Thanks a lot. I have found a small and light 18mm that I can keep on the road.
Thanks also for your link, it is very useful. I will make sure to complete my road toolbox!
Goryl
Mussels
3,207
Crowborough
Thanks Guys, your kind words are much appreciated! It is a two way street though. Most of the upgrades and improvements that have been made to Wisper bikes over the last four or five years have originated from comments made by Pedelec Forum members. I seriously appreciate the input.
I can't see a problem with retro fitting a connector into the motor cable. If you are a deb hand with a soldering iron it would only take half an hour or so.
Best regards
David
David,
I don't know how thick the 3 power cores are in the 905 cable but they may be difficult to solder with a domestic soldering iron. If the cable is thick then the wire carries the heat away quickly and the iron isn't powerful enough to heat the solder joint properly. I noticed the problem when I put a new fuse holder in my battery.
