I discovered the zip tie to true wheel, it really make it easy:
[video=youtube;F6w61ufBHj4]http://www.youtube.com/watch?v=F6w61ufBHj4&feature=youtu.be[/video]
I managed without too much problem to have lateral trueness. But my wheel isn't round at all. I tried to tighten the spokes in areas not round but doesn't seem to make any change...
Also, I didn't know the spoke on the gear side were longer than on the other side. I did a mismatch and had to un-lace the wheel to put everything back in place.
Now it's so much better
[video=youtube;G7BRS9d8Y-s]http://www.youtube.com/watch?v=G7BRS9d8Y-s&feature=youtu.be[/video]
It's impossible to get a good paint finish with some paints. The ones that prevent rust are the worse, and those that give a good finish are not very durable unless you want to use two-pack paints, which bring new problems. whatever paints you use, you shouldn't rub them down until it's properly hardened, which can take weeks.
Now I need to sort out my battery fitting in my bag:
Because the pack is now smaller, it doesn't stretch that much the bag and it's wobbling a bit inside. I need something to clamp it against the bag.
The bag should almost weight 15kg with controller and kryptonite lock:
[video=youtube;qDy4KVcn4y4]http://www.youtube.com/watch?v=qDy4KVcn4y4&feature=youtu.be[/video]
It doesn't feel so stable and move a bit. Can I leave it like this?
My front bag frame has been weakened due to the bag weight. It has cracks on the plastic now:
The bag wobble around when moving the handlebar left to right:
[video=youtube;7F-Dsv5c5xM]http://www.youtube.com/watch?v=7F-Dsv5c5xM&feature=youtu.be[/video]
I'm thinking to completely glue the frame to the front carrier bloc. Because I don't have the tools (or the cash) to CNC a new casing to replace the carrier.
