My goodness, it is a worthwhile upgrade. However, at least one model of 21.5" iMac can be problematical. We first replaced the hard drive when the original failed - that was a time to hold my breath as it was much newer and more valuable. Having done the hardware, we realised that the original drive was a bit of a special - and with a bog standard version the cooling fans ramped up to maximum after a few minutes.An SSD is a worthwhile upgrade by the way. My 2010 iMac runs very quickly with one fitted. Its an easy DIY job if you are careful!
But not for iPhone screens. When a later software update stuffs any that have non-Apple fitted replacement screens.in cases like this, independent repairers are godsend.
I’ve heard of the software fix for the fan issue. When I installed my SSD into a 29’ iMac I left the HDD drive in place and now use it only for large personal file storage such as video etc. I removed the DVD / CD drive and put the SSD in that bay using a chassis which I bought. I was able to carefully remove the temperature sensor off the DVD drive and re-attach it to the SSD, which means I don’t need the software. I’m not sure if it’s possible to do this on later models than mine.My goodness, it is a worthwhile upgrade. However, at least one model of 21.5" iMac can be problematical. We first replaced the hard drive when the original failed - that was a time to hold my breath as it was much newer and more valuable. Having done the hardware, we realised that the original drive was a bit of a special - and with a bog standard version the cooling fans ramped up to maximum after a few minutes.
There is a software fix for this - which worked.
When we realised how effective an SSD would be, we fitted a Samsung Evo. (Needed a mount adaptor as the original was full size.) The software carried on working - we assume. Performance leapt.
On the other hand, if you pranged your car so that you damaged the front wing and holed the radiator, you would expect to be able to purchase a new radiator, even for a brand new model. That is the situation those guys are facing. You might be expected to pay for it, but you would be supplied..Seems like a lot of drama about nothing, I you went and wrapped your car around a lamp post I expect the manufacturer would refuse to repair it and tell you it is a write off.
Except it was only released a couple of months ago so for normal people it isn't a problem. As I said before it's all drama.there are no authorised imac pro certified techs to fix it, the parts are there but they will not release them until someone has done the course that does not yet exist.
so any warranty problems will mean a hole new imac for a duff psu ect.
given the price this is outrageous, and i had a 5 grand mac pro that was not fit for purpose ill never buy apple products ever again.
They dismantled it and fess up they dropped it - so not surprising Apple won't fix it - it's in the first few seconds of the clickbait video you originally posted.normal ppl dont buy 10-15k computers that cant yet even be fixed under warranty buy any apple store
(From Nov 13th, 2010 mail and Dec. 7th follow-up)
"My Dual 2.7 G5 just went down. I followed the advice on your page and contacted AppleCare. It was escalated to a safety specialist when I mentioned concerns over the electrocution hazard. I was told I'd get a phone call back in a few days regarding Apple's resolution. The next day, I got a call back advising me to bring it to the nearest Apple store or repair facility, and the repairs would be free under an "exception code" noted to my serial number. I dropped the machine off today (at a NYC Apple Store), and the Genius Bar wrote up an estimate for $3,185.76 in estimated repairs, with $0.00 due (free). They advised me that it's standard for Apple to try to fix the machine, but with the cost to repair exceeding the cost to replace, Apple may simply provide me with a new machine free. We'll see what happens, and I'll update you with information as I hear more. I have both a Case ID number and Repair number I can provide, after I get resolution.
(And a later follow-up mail on Dec 7th, 2010)
Just an update... today I got a call from my local Apple Store, and they've opted to REPLACE the machine at their cost, with the base model MacPro ($2,499 one). It took 3 weeks to get to this point, but I'll be walking away with a new machine free. I've opted for the 8-core, so I'll be paying the difference ($1,000).
it's pretty amazing to me that the machine is replaced free, 5.5 years after purchase. Your page was invaluable to me in gathering the information for Apple to have a successful outcome.
Thanks, Mike I."
Againthey never said they wont fix it
