Anyone know anthing about trailers ?
I'm thinking of buying a trailer so that I can leave the car at home for the weekly (if I'm lucky :rolleyes: ) trip to Tesco's.
I've been looking at Flecc's impressive contraption and I've decided I wouldn't know where to start ... so it's plan 'B' - unfortunately this involves money :eek:.
I'm leaning towards a 'Ridgeback CT2'
CT2 2-Wheel Cargo Trailer - CycleExpress
... as prices go it's at the cheap end - and that appeals :D but I can't find any dimensions - does anyone know how big this is ? can anyone with a trailer explain the pro's and cons (where they attach, 1 wheel or 2 etc.). I've got a Wisper 905e and I'm reluctant to go anywhere near the back wheel - Its a *PIG* to get off and on again - for that reason the seatpost attachment looks good. It also attaches to the centre of the trailer which seems mechanically better than at the side.
Any ideas ?
The side attachment is much better John, seatpost attachments putting the nose weight too high up for stability. A heavy load can destabilise the bike due to the leverage a seatpost point has, and that's why there aren't many like this. However, given the relatively small size of that trailer it shouldn't be a problem, unless you're loaded right up with heavy bottles of booze. :)
Side attachments are often via a clamp that fits across the rear frame tubes ahead of the spindle, so not interfering with it. The leverage at that smaller distance from the ground is much smaller so loads are more stable.
I prefer a rigid attachment, but some incorporate a spring which can give flexing that pulses a bike fore and aft as the trailer and load moves. That's usually only a problem with a really heavy load though.
I'm not too keen on the bike hod which has a reputation for tipping over when cornering, due to the weight of the load being vertically stacked. It's ok as long as corners are taken slowly. Another potential disadvantage for shopping is that stacking the weight of shopping vertically like that can leave softer items crushed, not a problem with a flat trailer.
Thanks John,
That's an interesting variation I hadn't seen before - especially looking at some of the 'specials' people have produced - I'd thought about taking my wheelie bin to the tip in the trailer (on the weeks where a once a fortnight collection is just not good enough !) but this 'Bike-hod' is a more stable arrangement.
Only problem is the price though :eek: ... still - I wonder if there are any on ebay ... hmmmm
Here comes a daft question but has anyone ever weighed a weeks shopping. I know that varies depending on your household (and appetite) but I was wondering if my bike would cope with the family shop that generally fills the trolley!!
I guess I will have to add up the labels to get an accurate figure.
Only way is to weigh everything at home Paul. I can reach around 7 kilos with a solo part week shop and don't buy booze, soft drinks or water, so a week for a four person family could easily be well over 50 kilos. For some I've seen with stacks of bottled water, coke and booze, they'd best stick to the 4 x 4. :D
Flecc,
Thanks for that insight - our posts crossed - so I think I'll scratch the idea with the wheelie bin :)
I was thinking about the pros and cons of side attachments to the trailer (i.e. pulling it only on one side rather than in the middle but you bring up another point; if the connection is clamped to the side of the bike is there a seperate ball joint further down to allow the arrangement to go round corners?
If it's any help ..... I've just fitted a Mule Cargo Trailer to my Cougar Mountain Electric Bike.
At the time I didn't think about the attachment to the bike and it turned out that it was supposed to fit to the wheel. That would have been difficult as it was the side where all the wires go into the wheel.
My frame already had plenty of metal and two unused holes just above the wheel fixing point so I just utilised a short length of steel channel that was lying around and bolted it to the two holes I then attached the trailer to the channel (wheel untouched). Works a treat.
Picture of trailer attached to my bike.
Mule Trailer on Flickr - Photo Sharing!
I got the trailer from Bike Care
Cycle cargo utility trailers, box carriers, Bike care, Mission, Avenir Mule, Eco trailer, Spokey Joe
... but I was wondering if my bike would cope with the family shop that generally fills the trolley!!
Thanks Paul, Flecc,
Another good point - I was forgetting about the weight of all the liquids - kids' bottles of juice, coke, milk. After all, the bike must be quite stretched with my 13 st. :D
More thought required
Liquids are definitely the killer for many family shopping loads, the rest is not a problem.
The side or top joint takes various forms. A ball joint occasionally, sometimes a double pivot in two planes, often just a strong spring which flexes and bends enough to allow the steering to be relatively unhindered.
Footie,
I'd looked at the Mule Cargo - and it's a possibility (the right end of the price scale :)) - that attachment to the wheel nut could be a problem though - I've not got any spare holes in my frame - would have to clamp it to the frame - but still a possibility
John, have a look at the photo below of the prop stand on my Q bike. These are in most bike shops and quite cheap. Knock ot the stand leg rivet and discard the leg and that would make a strong hole to fix the trailer side attachment to:
http://users.tinyworld.co.uk/flecc/images/propdwn.jpg
There is a great deal of useful information and a Free Plan for a trailer at Carry Freedom - Award winning UK bicycle trailer maker.
A stainless steel rear spindle hitch is offered at £15.
Their City trailer is the nearest thing to my own and shows real ingenuity - theirs that is, but it tows central to the bike.
The body of my trailer is 20 inches front to back, 30 inches side to side, the nearside wheel tracks 3 inches left of the bicycle wheels. I do not cycle without the trailer and I have never had reason to feel insecure in traffic for 20+ years.
My drawbar telescopes into the frame giving an alternative length for long loads or a walking handle. The hitch is to or near the right of the rear spindle on my bikes and the seat of my class 3.
Dave
Edited by Orraman
Orraman makes a good point about a tow bar which also functions as a "walking handle". I have a Burley Nomad cargo trailer which clamps to the frame just in front of the axle. (The hitch is flexible for cornering.) It's a good system in that nothing needs to be permanently attached to the bike, but if I'm moving the trailer off the bike, I can't use the towbar as a handle, because if I raise it to hand height, the back of the trailer is scraping the ground.
Trailers like the CT2 or Bike-Hod which clamp to the seat post don't have this problem. The tow-bar is at a convenient height for hand-pulling, but as previously noted, it's less stable for cycling.
My other trailer is a Cyclone by Radical Designs. I use this with my unpowered Brompton. It hitches to a ball which needs to be fitted to the rear axle. (Just undo and re-do a nut, not too difficult even for a wimpy female!) The wheels have 2 positions, central for cycling or further back for walking, and changing them takes only seconds. The advantage of this trailer is that it's a framed hold-all. You can quickly stow away the wheels and towbar, then it's just a piece of luggage. Fold the Brompton into its bag as a second piece of luggage, and you're ready to get on the train. (But I'm digressing from e-bikes and shopping... sorry...)
Mary
Bikerev
John, I've used the Bike Hod for many years and have always been very happy with it. It has a large,easily detachable bag. The trailer has always been very stable when loaded and at speed. More recently,I've purchased a suitcase trailer from BicycleR Evolution Bike Trailers in the U.S. It is very good. More importantly, it can be supplied as a kit enabling one to construct a trailer to meet one's own needs.Hope this helps.
Steve
My other trailer is a Cyclone by Radical Designs. I use this with my unpowered Brompton. It hitches to a ball which needs to be fitted to the rear axle. (Just undo and re-do a nut, not too difficult even for a wimpy female!) The wheels have 2 positions, central for cycling or further back for walking, and changing them takes only seconds. The advantage of this trailer is that it's a framed hold-all. You can quickly stow away the wheels and towbar, then it's just a piece of luggage. Fold the Brompton into its bag as a second piece of luggage, and you're ready to get on the train. (But I'm digressing from e-bikes and shopping... sorry...) Mary
Very interesting Mary, Im very interested in that Brompton setup with the trailer and heres a daft question (but here goes), when you put everything in the bag, do you have any room left for what you were trailing? Do you have any pics?
John
Steve
I probably corner too fast, I've even managed to tip over my wide large trailer twice! :)
I found the Bike Hod with weight loaded right up to the top just tipped too easily, especially with adverse camber. Interesting that Waitrose are trying them for customer use now though.
The integral Cyclone bag is about 100 litres. If I'm planning to do the stow-away bit, I need to not fill it more than about 3/4 full, which is still a fair amount of luggage. That leaves space in the top for the two 16" wheels, and the towbar slides in anywhere. I have used this setup to go by train from Oxford to Inverness, then bus to Ullapool, and CalMac ferry to Stornoway, with camping kit and clothes for a week. Keep it all packed for lifing on and off public transport. Takes about 5 minutes to unfold and get everything back on wheels for moving around.
I think I have photos - I'll check this evening.
Mary
BF trailer
John,go to the BF homepage and click on "standard airline suitcase",it shows the Samsonite case and trailer. Alternatively, download the catalogue.Now only if I could afford the Bionx.
Steve
Very interesting Mary, Im very interested in that Brompton setup with the trailer ... Do you have any pics?
Hi John,
I find I've never yet taken a picture of the setup on the road, but this is it all packed ready for the train:
http://farm4.static.flickr.com/3057/2537166166_667c26c919.jpg
The light blue bag is the small backpack I carry for camera etc. The Brompton is in the navy blue bag at the back (I think I packed my helmet with it). The Cyclone trailer is red & black. It doesn't have a handle on the side, so I put a couple of straps round it for easier handling. You can just see the hole in the frame between the straps, which is where the wheel fits in for cycling. The other hole towards the back is where you put the wheel (one each side! ;) ) for walking with it.
The bag has a single zip which doesn't go quite the full length, so it wouldn't be easy to load with large single items. And it has no internal divisions, so I put a few dees on the bottom so I can strap stuff in place if I have a half load.
You can get more info on the trailer here: Radical Design Cyclone trailer
Mary
I find I've never yet taken a picture of the setup on the road, but this is it all packed ready for the train .....
That's a very smart set-up you have there Mary - I like it :D
Hi John,
Mary, how do you carry all that AND run for the train at the same time :confused:
I'd much rather be riding the bike, pulling the trailer and photographing the train !
