M mike killay Esteemed Pedelecer Feb 17, 2011 3,012 1,629 Feb 27, 2018 #21 I take it that you have tried disconnecting the brakes. Sometimes the switches inside them can stick.
B Birger Bulukin Finding my (electric) wheels Dec 5, 2016 18 18 84 Nittedal, Norway Mar 15, 2018 #22 Have you checked that the speed indication works normally? If the indication shows above 25km/h when it should be below, the motor will cut out. d8veh said: One more thing to check before you go to any trouble. Check that the motor connector on the fork is pressed together all the way. Click to expand...
