Another tale of Punctures
6,592
halfords dont have a clue rim tape is rim tape lol and why have tl tyres on it if the rims are not tl ready as well. ;)
Reactions: Izzyekerslike
8,616
TL rim tape has adhesive backing so if it is stuck fast then its TL ready as SW say's ignore Halfrauds.
6,592
Gubbins
Tape is not stuck to rim. It is easy to peel it aside and see the spoke holes where there is a deepish recess down the spokes . So I will need to take that off and replace with the sticky stuff. Seen youtube vids how to do it and it looks easy enough..
Sent from my SM-G920F using Tapatalk
6,592
looks stuck down in the pic but its only 5 quid a roll ;)
6,592
no there not the same but i cant find any info on them rims.
if you tape them up you should still get a seal tho but might find high and low psi causes problems with the tyre staying on the rim.
prob best stick with tubes then ;(
Reactions: Gubbins
Gubbins
Best bet is a couple of slime tubes.. did ok on other bike.. 900 miles and no flats. This one 50 miles and one flat.. so far....
Reactions: soundwave
6,592
even tho my rims are tl ready i can still rip them off the rim if the psi is to low on the rear going round corners.
tho not had a problem since i put the sg tire on the rear with lot thicker side walls.
6,592
yeah that will work ;)
6,592
yes that is the same but say 29inc wheel but i think it will fit 26 and 27.5 just check first b4 you buy it.
just i have never used it as i have no spokes in side my rims.
Related Articles
